× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Different size HDDs in RN204
Bangali
Hi,
I have recently bought an RN204 NAS with 2x 3TB HDDs and wanted to expand this (2 bays are empty). Currently it is set up in RAID format (although I'm not sure what setting - X-RAID/RAID5 etc) But I wanted to know if I go and buy 2x 6TB HDDs for example, would that give me a total of 9TB space and would I have to do any tinkering?
Thanks in advance!
Message 1 of 3
Accepted Solutions
Guru
Re: Different size HDDs in RN204
With xraid, 2x3TB + 2x6TB would give you a 12 TB volume size.  The rule is to sum the drives and subtract the largest.
The NAS reports in TiB though, so it will report ~10.9
You'd put in the the first 6 TB drive with the NAS running, and wait for the resync to complete.  Then add the second.  The expansion will take a while - likely ~ 2 days (and will require at least one reboot).
If you have a full backup, I think it would be faster to do a factory reset with all drives in place, and then restore the data.
Message 2 of 3
All Replies
Guru
Message 2 of 3
Bangali
Thanks very much StephenB.. Much appreciated..
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2643 views
  • 1 kudo
  • 2 in conversation
Announcements
