Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disc Scrubbing Fails following 2 x 2Gb Memory Upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-10
06:24 AM
2014-09-10
06:24 AM
Hi All,
I've updated the memory in my ReadyNAS Pro 6 (which is populated with 6 x 1TB Seagate Drives with xRaid2 and dual drive redundancy) from the standard 1 x 1Gb DDR2 (6-6-6-18) to 2 x 2Gb DDR2 (6-6-6-18 4GB 2X2GB DDR2-6400-800MHZ KINGSTON KVR800D2N6/2G DIMM 240-pin RAM Modules). I've also tried 4GB 2X2GB DDR2 KINGSTON KVR800D2N5/2G DIMM 240-pin RAM Modules.
The device runs fine, but I have scrubbing configured on a weekly basis which fails after around 30 seconds after starting with either sets of the RAM modules installed. When I revert to the original 1 x 1Gb RAM module, the scrubbing runs fine.
I've tried turning scrubbing off, rebooting and reapplying scrubbing but the net result is the same
The ReadyNAS is running RAIDiator 4.2.26
Any thoughts
Regards
Martyn
Any thoughts
Regards
Martyn
Message 1 of 11
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-10
06:44 AM
2014-09-10
06:44 AM
Re: Disc Scrubbing Fails following 2 x 2Gb Memory Upgrade
Did you run the memory diagnostic?
Message 2 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-10
03:16 PM
2014-09-10
03:16 PM
Hi,
Yes, twice. No errors
Regards
Martyn
Regards
Martyn
Message 3 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-10
03:26 PM
2014-09-10
03:26 PM
Maybe run it for more passes. Clearly something is wrong, since the scrub failure clearly is tied to the memory.
Message 4 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-10
11:47 PM
2014-09-10
11:47 PM
Have ran memory test for 6 cycles with no errors
I then removed one of the memory stick so the NAS only had 1 x 2GB RAM and the scrubbing worked fine. So it appears the issue is related to the use of 2 memory sticks and not the memory itself
Martyn
Martyn
Message 5 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
04:14 AM
2014-09-11
04:14 AM
I have 2x1 GB in my pro-6, and scrubs work there. Some others have installed up 2x4 GB (viewtopic.php?f=110&t=48085).
Of course the pro-4 might behave a bit differently from the pro-6.
Message 6 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
04:18 AM
2014-09-11
04:18 AM
Is the memory properly seated?
Are the two 2GB sticks the same model?
If you download the logs (Status > Logs > Download all logs), what is the date in bios_ver.log ?
Message 7 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
08:45 AM
2014-09-11
08:45 AM
Hi,
Each set of 2 x 2Gb RAM is the same make/model and are seated correctly
The BIOS Version is 07/26/2010 FLAME6-MB V2.0
Regards
Martyn
Regards
Martyn
Message 8 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
01:07 PM
2014-09-11
01:07 PM
Sounds like the 3rd party memory you have is incompatible.
Message 9 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
04:50 PM
2014-09-11
04:50 PM
Yes, probably, but what is odd is that I currently have a single 2Gb memory stick from one of the kits installed and the scrubbing works perfectly. In fact it works on either of the 2Gb sticks from a kit, its only when both are installed at the same time it fails
Martyn
Martyn
Message 10 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-11
05:08 PM
2014-09-11
05:08 PM
Sometimes that can happen.
The only thing I can suggest is to try different memory or go back to the stock memory.
If you do upgrade the memory I do recommend running at least a few passes of the memory test before trusting it. Still memory can pass the memory test sometimes and still not be compatible so you would want to keep an eye on things for a while.
We don't support memory upgrades and in your system the stock memory works fine.
Message 11 of 11
