× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Disk 1 of 4 failed on RN424, degraded - Rebuild Steps?
BJB
@StephenB
Greetings!  You have helped me many times in the past and I have had many good years with my units.  Today I got the dreaded email that Disk in channel 1 changed state from online to failed on my RN424.  The light on that drive was red, and when I logged into the NAS the main page said "healthy" but degraded.
The log says Volume data health changed from Redundant to Degraded.
The NAS has powered down per its schedule as of now.  That also freaked me out until I realized that is the scheduled weekly shutdown!
My drive 1 and 2 are 10TB and 3 and 4 are 12TB
I am in the process of ordering another Seagate Ironwolf 10TBdrive same model and size of the one that failed. Although the model number varies a bit due to this being newer I assume? FWIW I had a ST10000VN0004 and now it is a ST10000VNA00. I think it relates to platter number and density but couldn't find definitively. I assume it is okay to use.
Can you please tell me the correct way to rebuild?  My NAS is currently off. Just put the new drive in and turn on?  Or boot it up first and THEN take out the drive and replace?  Anything else I need to do?  For my home NAS unit this is a first for me.  How long should it take? Kind of scary...
I use it primarily for PC backups and I have another copy of those in the cloud.
However there might be a few other files on there that are not on another backup.  Should I copy these somewhere before the rebuild or does that put stress on the remaining drives? Or can I copy during the rebuild or should I just let it rebuild first?
My NAS is not on the most current firmware so hopefully that is not an issue.
I think I am on 6.95 Hotfix 1.
Thanks,
BJB
Message 1 of 14
Accepted Solutions
Guru
Re: Disk 1 of 4 failed on RN424, degraded - Rebuild Steps?
It should be fine.
You can copy those off first.
Data blocks on the missing disk will be reconstructed on the fly from the others.  That is the same process that is done during the rebuild, but not as stressful because it uses a lot less data.
You can use either procedure - both hot swapping the drive when the NAS is running, or swapping when powered down will work.  The NAS detects the removal/insertion directly when hot-swapping, so there is no chance it will be confused.  On the other hand, if you were to accidently remove the wrong drive with the NAS running there would be a problem -so you need to be careful not to make that mistake.  That's not a concern with the NAS powered off (as long as correct drives are installed when you power up).  The NAS will still figure out what changed, as the new drive is blank/unformatted.
Though since you have some files you want to back up, I suggest
  • removing the failed drive while the NAS is powered down
  • booting up with bay 1 empty, and copying off the files
  • hot-insert the new disk into the empty bay.
No chance of accidentally hot-removing one of the remaining drives, since you are only hot-inserting.
Also, if you can connect the new disk to a PC (either SATA or with a USB adapter/dock) then I recommend testing it with Seatools before putting it into the NAS.  I generally run the full "long" test, and follow that up with the full "erase" test.  I've had a couple of new out-of-the-box disks that passed one of these tests and failed the other.  It will take some time (maybe two days to run both), but I like to be sure that the new disk is working ok before I put it into the NAS.  Don't format the drive in the PC - Seatools will find the drive and test it unformatted.
Message 2 of 14
All Replies
Guru
It should be fine.
Message 2 of 14
BJB
@StephenB
Thanks for that AWESOME step-by-step reply! This makes me more comfortable.
I will definitely do the SeaTools test first.  I recently had a new WD Black regular PC drive fail to initialize in a PC.  Had to get another which worked fine.  Don't want that happening with the NAS!
I have a USB3.0 SATA hard drive dock so will use that to run the tests.  In fact, I may just run it on a spare laptop so it doesn't keep my main PC occupied.  I want to make sure I run the correct tests.
Under SeaTools Advanced, I see Long Self Test which is what you recommend.  Under Erase, "Long" there is "Sanitize Overwrite", "Simple Overwrite", and "Write Same Erase"?  Which of these 3 long erase tests should I run?
I will be antsy waiting two days to bring my NAS back to life but this sounds like the smart move 😀
Will run the tests, then bootup the NAS with the bad drive REMOVED, copy those files to another drive, then hot-insert the new drive after testing. I am 100% sure which drive is bad as I have the log snip and email documenting it. Just need to do after having had enough coffee.
You didn't mention the firmware so I assume I am okay with the version I am on.
For now I have unplugged the NAS so it does not startup and do an incremental backups.  I don't see the need to wear the remaining 3 drives just in case....
Thanks again!
BJB
Message 3 of 14
BJB
I couldn't edit my last post....the extended tests have both Long Self test and Long Generic test.  Not sure which one is the right one to run for that either.
Thanks,
BJB
Message 4 of 14
Guru
I'd run the long generic test and the simple overwrite.
Message 5 of 14
BJB
Thanks!
BJB
Message 6 of 14
BJB
Thanks again for your help.  I was hoping to report back on progress, but the long generic test was at 97% after 4 days, and I made the mistake of inserting a USB drive in the same PC and then removing it.  The test stopped with no results.  I didn't even "safely remove". So probably 4 more days from this test being done again and then who knows how many more days for the simple overwrite.
I guess it is worth it though to be safe and know you have a good drive.....
Thanks,
BJB
Message 7 of 14
Sandshark
Sensei
Four days and the test hasn't even completed seems to indicate it's running into a lot of errors.  On my PC, testing a 10TB drive takes about 12 hours.
Message 8 of 14
BJB
Interesting.  I had read somewhere that for a USB enclosure this seemed about right.   I am running a USB enclosure on an average computer.  10TB drive.
Perhaps yours was with an internal SATA connection?
I guess I will know in 4 days?!
BJB
Message 9 of 14
BJB
😀You motivated me to find a PC I could hook it up internally and am running it that way this time.
BJB
Message 10 of 14
Guru
Four days is definitely a lot longer than I've seen.
Is the enclosure (or the PC port) USB-2?  That would explain it.
Message 11 of 14
BJB
I should have done this from the jump. I connected the drive to the motherboard and it is completing about 10% an hour!. And I bet you are right, although the enclosure was USB the port may not have been.
Thanks,
BJB
Message 12 of 14
BJB
@StephenB ,
Both tests ran successfully, and I followed your instructions exactly.  All went well and volume is resynch'd.   Thanks again for all your help!
@Sandshark ,
And thanks to you for nudging me to connect the drive directly to an internal SATA connection.  Your time estimate was spot on, basically a day for each test.
Thanks,
BJB
Message 13 of 14
Guru
@BJB wrote:
@StephenB ,
@Sandshark ,
I'm glad we were able to help.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1345 views
  • 5 kudos
  • 3 in conversation
Announcements
