Kazura
Jul 20, 2012Aspirant
Duo v2, can't do factory reset
I just recently bought a ReadyNAS Duo v2, but when I tried it I got the Corrupt Root message.
After this i tried to do a factory reset, but either I am doing something wrong or the factory reset doesn't work.
What I have tried so far is, Push the small button on the back in (the one that says SYS), then turn the NAS on.
After the lights "settle" I then click the backup button, when i do this all the lights go out.
After this nothing happens when I click the backup button (it's supposed to change the lights?)
The power button also doesn't work when i try to power down (only works when I power up).
I tried to hold it in for 5+ seconds, double click, single click, but no luck.
EDIT:
I was now able to do a factory reset. But after the reset was done it still says corrupt root. Is there anything else i can try?
EDIT:
- HERBIEOAspirantAre you sure you have a Duo v2 how to tell look here > http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
if you do have a Duo v2 intructions for factory reset here > http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu - KazuraAspirantYeah I have now been able to do a factory reset but after the reset I still get corrupted root error.
- mdgm-ntgrNETGEAR Employee RetiredSo is it a Duo v1 or a Duo v2?
This suggests you could have a bad disk or bad memory.
Have you tried running the memory test?
