Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
[Fixed] ReadyNAS Duo V1 does not boot with 2 TB ST2000DM001
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-29
05:12 AM
2013-12-29
05:12 AM
Hi to everybody,
I am new to this board and I need support on my ReadyNAS Duo V1.
I bought an used empty unit and wanted to add 2 x Seagate ST2000DM001-1CH164 which are listed on the HCL. But the ReadyNAS does not boot while both HDDs are plugged in. The power LED is always on and the chassis fan runs at maximum speed but nothing happens. Also no access by Frontview.
With just one HDD the ReadyNAS boots and I can add the second HDD by hotplugging. Then the second HDD is being formated and the sync begins. But if I power down the ReadyNAS and want to power up againg there is the same issue like mentioned above.
I also did factory reset by pressing the reset button for 20 seconds and I also installed the firmware 4.1.12. by usb flash und have done the update to 4.1.13 again. But without success.
ReadyNAS DUO V1, no memory upgrade.
RAIDiator 4.1.13
2 x HDD Seagate ST2000DM001-1CH164 (Firmware: CC27)
X-Raid configuration
Can anybody help me please?
Thanks, Michael
RAIDiator 4.1.13
Thanks, Michael
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-29
05:54 AM
2013-12-29
05:54 AM
Re: ReadNAS Duo V1 does not boot with 2 x 2 TB ST2000DM001
A factory reset is done by powering off the system, pressing and holding the reset button, powering on the NAS, continuing to hold the reset button for about 30 seconds (not 20) until the disk LEDs blink twice and you see the factory default option appear on the display on the front of the unit then releasing it.
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-29
07:57 AM
2013-12-29
07:57 AM
I am sorry but this is a ReadyNAS Duo and there is no display.
According to the manual 20 seconds are necessary for factory reset. After 20 seconds the disk LEDs blink twice.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-29
12:25 PM
2013-12-29
12:25 PM
I am sorry, mdgm. You are right. It is 30 seconds. I had a wrong value in my mind. My tests I have done waiting 30 seconds.
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-10
02:15 PM
2014-01-10
02:15 PM
Re: [Fixed] ReadyNAS Duo V1 does not boot with 2 TB ST2000DM
Problem solved. New power adapter.
see http://www.readynas.com/forum/viewtopic.php?f=64&t=74690
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-12-28
12:47 PM
2014-12-28
12:47 PM
Independently from your problem, I understand you're able to use 2 TB ST2000DM001 (Seagate) SATA III disks on your ReadyNas Duo V1, isn't it ?
I'm looking for this information, since I'm going to replace my faulty 1TB disk with a brand new 2TB and your post is the unique information I found about that.
What I'm actually looking for is to be sure these disks will fits.
Thank you in advance for your answer.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-12-28
01:44 PM
2014-12-28
01:44 PM
Hi gundam,
yes, I am using 2 pieces of Seagate ST2000DM001-1CH164 (Firmware: CC27). Everythng is working fine.
Starting current of this type of drive is 2.5 Amps. So 5 Amps in total plus the chassis fan at startup. Should you experience any problem replace the original switching adpator by a new one of at least 5 Amps. The original is worn then and is no longer able to supply the 5 Amps. Please see viewtopic.php?f=64&t=74690.
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-12-28
01:50 PM
2014-12-28
01:50 PM
Generally I suggest searching the forum for the drive model you are thinking about prior to purchase.
gundam wrote: Independently from your problem, I understand you're able to use 2 TB ST2000DM001 (Seagate) SATA III disks on your ReadyNas Duo V1, isn't it ?
I recommend NAS purposed drives (WDC Reds are what I use, Seagate's VN line is their equivalent). Their warranties are better than consumer drives, and the manufacturers intend them for use in RAID arrays.
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-12-28
03:05 PM
2014-12-28
03:05 PM
Thank you both for your fast answers.
StephenB, do you think with WD20EFRX I can avoid the 5A problem experienced by mdietric ?
This seems to be (from reviews I had a look) a better disk tha MD series from Seagate, even if it cost a little bit more. If I would consider the supply adaptor cost, and I'm sure this will be not needed for WD, probably the difference will be very limited.
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-12-28
03:28 PM
2014-12-28
03:28 PM
I use a WD20EFRX in my duo with no problem (though the second drive is a ST32000542AS). The EFRX line runs cool, and don't draw much power. They shouldn't overload the adapter unless it is already failing.
Message 10 of 10
