× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
How do I backup my datas from local remote system to NAS?
avsathish
Follower
I am trying to backup my local system datas to NAS box but did not. Here are my backup job settings.
Source:
Type: remote
Name: remote: Windows/NAS (Timestamp)
Host: <local ip-192.168.1.1>
path: <local system sharing drive - D>
login: <local system username>
password: <local system password>
Destination:
type: share
host:
path:
login:
password:
schedule:
enable schedule: enabled
backup every: 24 hours
time: 00.05 to 23.05
But I can not backup files. It shows backup error message.
I am a new customer/user of Netgear ReadyNAS box. So can you someone answer my error.
Model: ReadyNAS Remote|,RN102|ReadyNAS 100 Series
Message 1 of 2
Guru
Re: How do I backup my datas from local remote system to NAS?
192.168.1.1 sounds like your router's IP address, not the PC.  Are you certain this is the correct IP address?
Also, if you have a second PC you might want to see if you can access the shared D drive from there (using the same credentials).
If not, you could use a mobile app to test access to the D drive - for example goodreader for IoS, or solid file explorer for Android.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3819 views
  • 0 kudos
  • 2 in conversation
Announcements
