× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
How to remove disk from Raid ?
dejanm
Hi,
I have ReadyNAS Duo with latest firmware. It has two disks inside, running in the Raid-X mode. One disk is a Seagate of 750 GB and the other one is WD of 1 TB. That means that the available disk space is about 700 GB.
I have at the moment used about 85% of a disk space. I would like to increase that space. The simplest way (at least that is what I believe) is to remove the smaller disk from Raid-X and to continue using NAS without Raid with only one disk, which should get then its full space capability of 1 TB. The question is: how to do that ?
I tried simply to remove smaller disk but Duo is still in Raid mode and reports that one disk is dead.
I will appreciate any hint ...
Message 1 of 3
sphardy1
Apprentice
Re: How to remove disk from Raid ?
Backup your data - Factory Reset with the one disk installed - Restore data from backup.
Factory Reset instructions in the FAQ
Message 2 of 3
dejanm
It worked without problems ...
Thanks a lot for this hint ...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2209 views
  • 0 kudos
  • 2 in conversation
Announcements
