- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Improve performance of ReadyNAS 316
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use ReadyNAS 316.
I am interested in performance improvement of my NAS but I do not know how to.
Are there any way to improve the performance?
Environment
Model: ReadyNAS 316 with 6 sata disks
RAID-mode: RAID-X
Share mode: SMB
Encryption: On
Current performance: 100 MB/s (seq read), 70 MB/s (seq write)
Network: 1Gbps
I think write is little slow since the encryption option is on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Improve performance of ReadyNAS 316
increase ram
use enterprise grade 7200rpm hard drives
upgrade to 516 or 716 as they use faster cpus
- Mark as New
- Bookmark
- Subscribe
- Permalink
You won't see much faster read performance, since you are close to the 1 gb limit already.
You could try jumbo frames - I'm not a huge fan of them myself, but they can improve speeds with some clients. You'll need to ensure that you pick the right MTU for your clients and the switches between the clients and the NAS.
if your volume is old, you could try a factory reset. There are some settings changes that Netgear has made over the past releases that only are applied to new volumes.
But I think you are likely correct in thinking encryption is the cause of the slower write speed. You might also want to consider why you use drive encryption. What benefits do you see? If you leave the key in the NAS there really isn't any security benefit. Someone stealing the NAS+key can do an OS reinstall, and gain full access to the NAS using the default admin password. Plus it doesn't protect from network threats.
@cpu8088 wrote:
increase ram
If you are CPU bound due to encryption, then you won't see much speed gain with enterprise drives. More RAM could help some if you are running out, but I don't think it will get you to 100 MB/sec write speeds.
