× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Invisible Snapshots - Access Denied To Upgrade
brizzad
I have a ReadyNAS 102 running 6.9.2 firmware.
I have 1.70TB of Snapshot data that is inaccessible. I cannot browse them in the Web UI.  From browsing/searching these forums, it sounds like a bug - that the snapshots were not upgraded after a previous firmware upgrade?
I attempted the command reccommended in other threads:
  • touch /.force_snapshots_upgrade
However I get a Permission Denied as per attached screenshot. What should I be trying next?
Model: RN102|ReadyNAS 100 Series
Message 1 of 3
Accepted Solutions
Guru
Re: Invisible Snapshots - Access Denied To Upgrade
You are using SSH logged in as admin.  You need to log in as root (using the NAS admin password).
Message 2 of 3
All Replies
Guru
Message 2 of 3
brizzad
Well that's embarassing 🙂
Thanks for pointing out the obvious.  I have logged in as root now and the commands run without issue.
After logging into the Web UI - I see that it is upgrading the snapshots now (attached screenshot).
It has finished upgrading all snapshots - and I can now access them in the UI to delete them.
Thank you so much!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 704 views
  • 1 kudo
  • 2 in conversation
Announcements
