× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Is RAID 5 hot swap as is RAID 1?
digitaldentistr
On ReadyNAS Pro2 products with 2 drives, you could just wap the drives from one unit to another (putting in same exact location) and it didn't require any configuration or setup.  Is this possible for the newer ReadyNAS products like 312, 516 and in RAID 5 configuration?
Message 1 of 5
Accepted Solutions
Guru
Re: Is RAID 5 hot swap as is RAID 1?
You can migrate disks to a compatible unit (just like the ultra/pro 4.2.x systems).  That is, you could migrate from an RN300 NAS to an RN300/RN500/RN700 system, as long as it has enough drive bays.
This isn't "hot swap" since the systems are powered down when you migrate the drives.  Your use of "hot swap" in the title is perhaps complicating the replies.
Message 4 of 5
All Replies
cpu8088
Virtuoso
312 is a 2 bay unit
raid 5 needs at least 3 drives
hot swap is a separate feature different from raid levels
Message 2 of 5
mdgm-ntgr
NETGEAR Employee Retired
Hot swapping refers to replacing failed disks or disks that you no longer wish to use while the NAS is on.
Migrating disks to another unit you would power off both units first.
What exactly are you looking to achieve?
Note that our new units use a new OS and different filesystem to your Pro 2.
Message 3 of 5
Guru
Message 4 of 5
digitaldentistr
Yes sorry, didn't mean hot swap.
Meant taking disks out from one unit to another after shutting it down.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2915 views
  • 0 kudos
  • 4 in conversation
Announcements
