Orbi WiFi 7 RBE973
Reply
'Management service is offline' after 6.7.4 upgrade
CDStoneley
I inadvertantly kicked off the firmware update to 6.7.4, and now although my RN314 has rebooted, and the display cycles between displaying
ReadyNAS 314
6.7.4
and displaying the current state of a resync on the expansion volume (EDA500), I cannot access the Admin Page. The browser continually recycles at the end of the thermometer bar, and RAIDar lists "Management service is offline" as the status. (Both reflect Firmware: 6.7.4).
I found an earlier thread and re-kicked off the firmware update, incase it hadnt completed - no change.
I've downoaded the logs but don't even know where to start with the litany of files that that brought...
Diagnostics is full of messages like:
  • 2017-06-08 11:30:20: readynasd[21297]: segfault at 0 ip 0000000000484250 sp 00007fcd853e8750 error 4 in readynasd[400000+13b000]
  • 2017-06-08 11:29:40: readynasd[20849]: segfault at 0 ip 0000000000484250 sp 00007f0f16ed0750 error 4 in readynasd[400000+13b000]
  • 2017-06-08 11:29:05: readynasd[20303]: segfault at 0 ip 0000000000484250 sp 00007ff7cb7fd750 error 4 in readynasd[400000+13b000]
Any suggestions?
Model: EDA500|ReadyNAS Expansion Chassis 5-Bay,RN31400|ReadyNAS 300 Series 4-Bay
Message 1 of 26
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: 'Management service is offline' after 6.7.4 upgrade
You may have run into an issue fixed by 6.7.5 Beta 1
You could download the firmware update and install it via https://ip.address.of.nas/fwbroker
Message 2 of 26
All Replies
mdgm-ntgr
Message 2 of 26
CDStoneley
Up and running on the Beta. Thank you.
I had a phantom old Volume which i had to delete (some SSD experiments) and it seems I have to share my primary shares on the RN314 volume again, but I'm running again. Many thanks!
Chris
Message 3 of 26
nativevml
Hi There,
first timer here so apologies for the terminology, I have a RN 2120v2 with FW: 6.7.4,
the status is Management service is offline, my drives are healthy and I can browse the shares and the diagnostics doesn't show any errors whatsoever.
I have critical data on the drives so I cant afford a reset.
Please can you assist me?
Thanks in advance.
Message 4 of 26
Guru
Then the first step is to back that data up right away.
After that, likely the fastest way to get this resolved is to use paid netgear support (my.netgear.com). There is a per-incident support option that gets you one hour of support time.
Does https://nas-ip-address/fwbroker respond? Use the real NAS IP of course.
Message 5 of 26
nativevml
Hey Stephen,
yes that does respond.
Message 6 of 26
Guru
Good.  Try installing 6.7.5 using that interface.  There are some fixes that might apply (though it is not guaranteed) https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5
Unzip the download, and only install the img file.
Message 7 of 26
nativevml
I sent my Logs to Marty, should I wait for his response first?
Message 8 of 26
Guru
Yes.
Message 9 of 26
laithabdul
Hi
after used https://ip-readynas/fwbroker
i get this message
ERROR 6001010006
Couldn't resolve host name
Model: RN4220S|ReadyNAS 4220 2xSFP+
Message 10 of 26
Guru
Where are you seeing this message?
Message 11 of 26
laithabdul
Hi
I have readynas4220
firmware : 6.7.4
status : management service is offline
when use https://nas-ip-address
request username and password after give user and pass i get connecting to the ReadyNAS Admin Page
after used https://nas-ip-address/fwbroker
i get this message
ERROR 6001010006
Message 12 of 26
Guru
Is this after you upload/install the firmware?  Or when you try to upload/install the firmware?
Message 13 of 26
laithabdul
after upload and install the firmware
Message 14 of 26
Guru
In some past posts, this was linked to quotas being enabled on a volume with a lot of snapshots.
Try rebooting the NAS - if that doesn't help, try to do an OS reinstall from the front panel.  With current firmware the OS reinstall should clear the volume quota setting.  It also resets the admin password to password and the network configuration to use DHCP.  Data and other settings shouldn't be affected.
Message 15 of 26
laithabdul
I dont have data How do OS reinstall from front panel and how resets to default Thanks
Message 16 of 26
Guru
The boot menu options for the 4220 rackmount ReadyNAS are on page 33-34 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS_6_Rackmount_HW_UM_10Dec2014.pdf
Message 17 of 26
laithabdul
I did the same steps and did not return defualt
Message 18 of 26
Guru
If you want to do a factory default, another way is to zero or unpartition the disks.  For instance, connect the drives to a windows system, run the windows disk manager, and then delete all the partitions ("volumes" in windows parlance) on the drives.
Message 19 of 26
nativevml
Smiley Very Happy
DUDE!!! I did the https://x.x.x.x/fwbroker and it worked!!!! thank you to @Marty_M and @StephenB and @mdgm-ntgr Smiley Very Happy
Message 20 of 26
laithabdul
I want to do a factory default readynas  rn 4220.
I want any way to access the readynas
Thanks
Message 21 of 26
Guru
There are two ways I described earlier in this thread
  • boot menu
  • power down, unformat all the disks, then power up
Did you try either of those?
Message 22 of 26
laithabdul
The first method (boot menu) did not work
The second methode (unformat all the disks) I did not understand it needs more detail
Thanks
Message 23 of 26
Guru
  • Connect each disk to a windows PC (USB or SATA).
  • Open the windows disk manager (entering diskmgmt.msc on the run line will work).
  • At the bottom of the disk manager window you will see each disk in the system.  There's a graphic next to each disk that shows every partition (which Windows calls "volumes" for some reason).
  • Right click on each partition in the graphic, and select "delete volume"
  • Put all the disks back into the unpowered NAS and turn it on.  It will do a factory install (since all the disks are blank).
Message 24 of 26
laithabdul
Thank you stephenB
I solve second methode unformat all disk
Regards
Message 25 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 7540 views
  • 1 kudo
  • 5 in conversation
Announcements
