Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mount ReadyNAS NV+ RAID disks in Linux - Input/Output error
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-03
04:28 AM
2011-11-03
04:28 AM
Hi all,
I know this topic has been covered many times in these forums and other places on the net, but I am still having trouble accessing the actual files on the NAS disks. I have come frustratingly close to being access the files, but not close enough! I'd like to know why my directory listing of the mounted raid looks like this?:
and what do I need to do to access the files in the folder "testshare"?
Some background info:
I have two identical ReadyNAS NV+ with four 750GB drives in each of them, using x-raid (giving ~2TB storage). One of them is totally messed up, and one is just fine. The working one is basically empty - it only has 8 jpeg images stored in a share called testshare. My thinking is that I need to prove that I can recover 8 lousy jpegs from the one that is working before I will have any chance of recovering thousands of precious jpegs from the trashed one 😞
My test setup:
MacBook Pro running VirtualBox, with a VM running ubuntu 10.04. lvm2 and fuseext2 are installed. I have created four virtual hard disks, each 698.64 GB, and attached them to the VM. I have created another virtual disk, which I use for accessing a physical hard drive attached to the host via a USB SATA adapter. I have cloned, one-by-one, each of the four disks from the working NV+, though only the first 5 GB, assuming that this should be more than enough data from each disk to be able to access the less than 20 MB of files on the RAID volume.
For cloning from the physical disk (always /dev/sdf) to each of the raid disks (/dev/sdb, sdc, sdd, sde) I used:
dd if=/dev/sdf of=/dev/sdb bs=512 conv=noerror,sync count=10485760
Here is the result of mounting and trying to access the raid volume:
So close! :shock: What am I missing here?
Here is a list of my drives:
Here is the xraid_config.log from the working NV+:
And the partition.log from the working NV+:
Hope you guys can help!
-Rexpo
root@ubuntu:/mnt# ls -lasc
ls: cannot access backup: Input/output error
ls: cannot access media: Input/output error
ls: cannot access home: Input/output error
ls: cannot access .timemachine: Input/output error
ls: cannot access testshare: Input/output error
total 68
16 drwxrwxrwx 8 root root 16384 2011-11-02 15:24 .
4 drwxr-xr-x 22 root root 4096 2011-11-02 20:40 ..
16 -rw------- 1 root root 7168 2011-11-02 15:28 aquota.group
16 -rw------- 1 root root 7168 2011-11-02 15:28 aquota.user
? -????????? ? ? ? ? ? backup
? -????????? ? ? ? ? ? home
16 drwx------ 2 root root 16384 2011-11-01 19:57 lost+found
? -????????? ? ? ? ? ? media
? -????????? ? ? ? ? ? testshare
? -????????? ? ? ? ? ? .timemachine
root@ubuntu:/mnt#
My test setup:
root@ubuntu:~# pvscan
PV /dev/sdb5 VG c lvm2 [696.41 GiB / 0 free]
PV /dev/sdc5 VG c lvm2 [696.41 GiB / 0 free]
PV /dev/sdd5 VG c lvm2 [696.41 GiB / 5.00 GiB free]
Total: 3 [2.04 TiB] / in use: 3 [2.04 TiB] / in no VG: 0 [0 ]
root@ubuntu:~# vgscan
Reading all physical volumes. This may take a while...
Found volume group "c" using metadata type lvm2
root@ubuntu:~# vgchange -a y c
1 logical volume(s) in volume group "c" now active
root@ubuntu:~# lvscan
ACTIVE '/dev/c/c' [2.04 TiB] inherit
root@ubuntu:~# fuseext2 -o ro /dev/c/c /mnt
root@ubuntu:~# cd /mnt
total 68
root@ubuntu:/mnt#
root@ubuntu:~# fdisk -lu
Disk /dev/sda: 21.5 GB, 21474836480 bytes
255 heads, 63 sectors/track, 2610 cylinders, total 41943040 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0002658d
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 40105983 20051968 83 Linux
/dev/sda2 40108030 41940991 916481 5 Extended
/dev/sda5 40108032 41940991 916480 82 Linux swap / Solaris
Disk /dev/sdb: 750.2 GB, 750158987776 bytes
255 heads, 63 sectors/track, 91201 cylinders, total 1465154273 sectors
Disk identifier: 0xb443b91b
/dev/sdb1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/sdb2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/sdb3 4608002 1465112305 730252152 5 Extended
/dev/sdb5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/sdc: 750.2 GB, 750158987776 bytes
Disk identifier: 0xb443b6e1
/dev/sdc1 2 4096001 2048000 83 Linux
/dev/sdc2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/sdc3 4608002 1465112305 730252152 5 Extended
/dev/sdc5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/sdd: 750.2 GB, 750158987776 bytes
Disk identifier: 0xb443b6d3
/dev/sdd1 2 4096001 2048000 83 Linux
/dev/sdd2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/sdd3 4608002 1465112305 730252152 5 Extended
/dev/sdd5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/sde: 750.2 GB, 750158987776 bytes
Disk identifier: 0x00000000
Disk /dev/sde doesn't contain a valid partition table
root@ubuntu:~#
VERSION/ID::superblock=(0.1.0),ID=a201e221.00000000.00000000.00000000,create_time=4eb03fb5
RAID_INFO::disks_total=4,raid_disks=4,parity_disk=3,disks_online=4,disks_working=4,disks_failed=0,spare_disk=0,base_disk=0,size=1465128688,update_time=00000000,state=0,luns=2,extcmd=1,expandable_bitmap=0x0,lsize=1465128686,drive_present=0xf
LOGICAL_DRIVE:0:begin_sector=2,sectors=4096000,raid_level=1,status=redundant,initialized=1,dmap=f
LOGICAL_DRIVE:1:begin_sector=4096002,sectors=1461032686,raid_level=X,status=redundant,initialized=1,dmap=f
PHYSICAL_DRIVE:0:number=0,device=hdc,major=22,minor=0,raid_id=0,state=online,present=1,size=1465128688,r_model=ST3750640NS,r_size=1465128688,r_fw=3.AEG
PHYSICAL_DRIVE:1:number=1,device=hde,major=33,minor=0,raid_id=1,state=online,present=1,size=1465128688,r_model=ST3750640NS,r_size=1465128688,r_fw=3.AEG
PHYSICAL_DRIVE:2:number=2,device=hdg,major=34,minor=0,raid_id=2,state=online,present=1,size=1465128688,r_model=ST3750640NS,r_size=1465128688,r_fw=3.AEG
PHYSICAL_DRIVE:3:number=3,device=hdi,major=56,minor=0,raid_id=3,state=online,present=1,size=1465128688,r_model=ST3750640NS,r_size=1465128688,r_fw=3.AEG
RUN_PARAMETERS::raid_running=1,last_word=ok,interface_start_at=1,fake=0
RAID_REBUILD::sync=0,logical=0,parity=3,sectors=0,total=4294967295,source=f,total_drives=4,auto_sync=1
RAID_P_CHECK::chck=0,current_lun=0,total_luns=2,raid_level=0,err=0,current_sector=0,total_sectors=0,report_err=1
RAID_P_INIT::initialized_bitmap=0xf,initialize_error_bitmap=0x0,initializing_bitmap=0x0,current_sector=0,total_sector=0
Disk /dev/hdi doesn't contain a valid partition table
Disk /dev/hdc: 750.1 GB, 750145888256 bytes
255 heads, 63 sectors/track, 91200 cylinders, total 1465128688 sectors
/dev/hdc1 2 4096001 2048000 83 Linux
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdc3 4608002 1465112305 730252152 5 Extended
/dev/hdc5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/hde: 750.1 GB, 750145888256 bytes
/dev/hde1 2 4096001 2048000 83 Linux
/dev/hde2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hde3 4608002 1465112305 730252152 5 Extended
/dev/hde5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/hdg: 750.1 GB, 750145888256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 1465112305 730252152 5 Extended
/dev/hdg5 4608003 1465112305 730252151+ 8e Linux LVM
Disk /dev/hdi: 750.1 GB, 750145888256 bytes
-Rexpo
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-11-07
02:01 AM
2011-11-07
02:01 AM
Re: Mount ReadyNAS NV+ RAID disks in Linux - Input/Output er
5GB isn't enough data read from the disks to be able to get at the filesystems properly. I tried again with 10GB and it worked, though I believe that I got lucky - seems like shortcuts aren't such a good idea after all and that I need to dd the whole disks into my test VM.
Mystery solved.
-Rexpo
Mystery solved.
-Rexpo
Message 2 of 2
