Orbi WiFi 7 RBE973
NV+ V2 stalling when 80%+ full (20047616)
chirpa
Luminary
Re: NV+ V2 stalling when 80%+ full (20047616)
I would start by asking dratto what progress he's made.
dratto wrote:
I've asked for a refund under the New Zealands Consumers guarantees act as it states "do what they are made to do".
Message 126 of 198
hauser1
it appears as if he hasn't returned to these forums since he made that post going by the profile data for him publicly available: dratto
Message 127 of 198
hauser1
from what I've dug up so far for us Aussies:
http://www.fairtrading.qld.gov.au/consu ... -goods.htm
1. Acceptable quality wrote:
A business guarantees that goods will be of acceptable quality.
This means that they must be:
fit for all the purposes for which goods of that kind are commonly supplied - for example, a toaster must be able to toast bread
acceptable in appearance and finish - for example, a new toaster should be free from scratches
free from defects - for example, the toaster's timer should not fall off when used for the first time
safe - for example, sparks should not fly out of the toaster
durable - for example, the toaster must function for a reasonable time after purchase, without breaking down.
The issue we've all been having is that the NAS won't function to save more data once an amount of data is saved that is not 100% of the total size of the disks used.
Australian consumer rights from what I can tell would class this as a major problem: http://www.fairtrading.qld.gov.au/consu ... ailure.htm
What qualifies as a major failure? wrote:
A major problem with goods is when:
you would not have bought the goods if you had known about the problem. For example, you wouldn´t buy a washing machine if you knew the motor was going to burn out after three months
the goods are significantly different from the description, sample or demonstration model shown to you. For example, you order a red bicycle from a catalogue, but the bicycle delivered is green
the goods are substantially unfit for their normal purpose and cannot easily be made fit, within a reasonable time. For example, a ski jacket is not waterproof because it is made from the wrong material
the goods are substantially unfit for a purpose that you told the supplier about and cannot easily be made fit within a reasonable time. For example, a car is not powerful enough to tow your boat because its engine is too small, despite you telling the dealer that you needed the car to tow a boat
the goods are unsafe. For example, an electric blanket has faulty wiring.
as above none of us would have purchased the unit had we known that it would not save data after a point prior to being 100% full.
When goods or services do not meet a consumer guarantee wrote:
For goods, if the problem is major, you can:
reject the goods and get a refund or
reject the goods and get an identical replacement, or one of similar value if reasonably available or
keep the goods and claim compensation for the drop in value caused by the problem.
Message 128 of 198
hauser1
dratto wrote:
I asked Netgear about it and they advised me that it up to the store I got it from to replace the unit. Which is fair enough. The store has to ask for Netgear's permission anyways.
So I contacted the store and had to send the unit to them for testing. I advised them I have a case open with Netgear and quoted it. Also made sure the company know about the NZ consumers act. They have been very good and advised a new unit should be here next week. They are getting the newer model for me as all the old ones still have the issue. New model is RN10400. I have asked Netgear if this unit has the same issue and am waiting a reply.
Netgear did however get me to try two beta release firmwares that didn't fix the issue.
Hope this helps.
dratto
got this reply from dratto, hopefully I can use this forum's post and my open case with NETGEAR to get similar results from my place of purchase.
Message 129 of 198
Zaim
Anyone know if the New 104 replacement has this issue?
And does anyone know if the DLNA server is the same on the new unit?
Message 130 of 198
ihartley
Tutor
I have returned an NV+ v2 to my supplier with a (UK) successful resolution (a refund was not acceptable). I had a few tickets open with Netgear, and eventually they said:
"Please be advised that the Netgear warranty is a hardware manufacturers warranty and as such, we will replace the unit for a like for like model."
and...
"We welcome the list of features that you feel are not working and we can look into this and see if we can assist but please know that the warranty is a hardware one, this does not cover software after 90 days, we can replace units if there is only a hardware fault. "
Unfortunately, due to Vogon and global decency laws I am not able to reproduce my answers here 😄
IMHO the product is not up to the job, nor ever will be. It disappoints me. Not because a tech product has issues, but that the issues are FUBARing the exact capabilities I bought the product for in the first place. And that Netgear will not admit it.
Message 131 of 198
aks
Virtuoso
Virtuoso
What was the successful resolution then?
BTW, without trying to stir things up, merchantable quality, fit for purpose, etc, all apply to UK irrespective of warranty, so in theory we could still demand a replacement.
Message 132 of 198
Tokfan
Best sollution would be a 100% refund or a new machine from a different brand. 🙂
Message 133 of 198
de_niro
Guide
Hello guys,we confirmed this issue has been fixed in 5.3.8 and it will be released soon enough,we hope for your understanding and sorry for so much trouble.
Message 134 of 198
de_niro
Guide
Actually 5.3.8-T20 is able to fix this issue,we've merged all patches in but..... if it doesn't work for you,please backup data and factory default your volume,the reason is your volume could be badly fragmented and the file system needs to be rebuilt once again.
Message 135 of 198
chirpa
Luminary
But even with a factory default (not possible for many people), what happens when they hit fragmentation down the road again? Seems like a short term solution.
Message 136 of 198
janforman
That's strange. Can you describe what is exactly patched? It's some tweaks to default values or C source is modified somehow? Anyway I don't have any problems with ext3 and I can write 50MB/s constantly without any problems.
Message 137 of 198
hauser1
exactly and for me fragmentation should be low as I've hit this problem just in copying data back to the device from one computer with single thread copy after a factory default many times....
normally fragmentation is "bad" if you copy & delete files randomly large amounts of files over time.
Message 138 of 198
janforman
You are right, and when I try it with switchover ext3 <> ext4 with absolutely identical data (i mean 100%) - ext4 driver always lockup NAS completely.
There is no fragmentation and volume is mounted in backward compatibility with ext3 then IO kills all! So I can remount same partition with ext3 driver back and problem is gone.
That's why I am asking what is changed, because I saw some new kernel patches to ext4.
a) it's a driver bug
b) 256MB is not enough for ext4 of this volume size
if it's b) then some tuning may solve this problem.
But I don't understand why ext4 driver fails when have absolutely same conditions as ext3 (disabled extents, same data, everything is 100% same...)
Message 139 of 198
hauser1
there might be kernel patches to the main kernel src but iirc T20 didn't include a new kernel, they have just changed mount settings / scripts.
Message 140 of 198
tarkeen
That no fix. Do factory default mean all data loss. When you have proper fix ready? 5.3.8 T21? 5.3.9?
Message 141 of 198
hauser1
yes factory default's mean total data loss, you would have to backup and restore it each time it gets to the issue full % according to that post... NOT GOOD NETGEAR not good at all!
From the tone of the post I highly doubt a T21 or even a 5.3.9 that might actually fix the issue. if you can get your unit returned for refund if your country has laws protecting you from bad products like this one. within 1-2 days I hope to have my money refunded for this unit.
Message 142 of 198
Zaim
I seriously hope that isn't needed. Can you at least give us an ETA ?
Message 143 of 198
hauser1
an ETA for 5.3.8-T20? it's available over here. if it's a when will netgear have a working patch, I wouldn't hold my breath on that one.
Message 144 of 198
Zaim
Hmm so its out already, wonder why netgear support haven't sent me this.
Message 145 of 198
hauser1
netgear don't seem to like to have patches go out to everyone that's having an issue at the same time & keep you in the dark for ages.
they've gone sometimes more than a week between update messages to me in the support system, i've had more support from other consumers and community forum admin's than actual netgear employee's during the time I've had this issue.
Message 146 of 198
hauser1
I'm no rocket scientist but clearly there is something I'm just not understanding, can anyone spot what's wrong with their updates to me?
4/22/2013 11:29:00 PM
Notes added by 56018
Mr. Hauser,
This is Erick again and I am following up on your support case.
Please download the beta firmware using the link below and install it on the NAS:
https://dl.dropboxusercontent.com/u/215 ... -5.3.8-T20
Please let us know of the outcome.
XXXXX
NETGEAR support
5/13/2013 4:23:00 AM
Case Number: 20047616
Dear Mr. Hauser,
Can you please try to upload the firmware by downloading it on the link below:
XXXXX
NETGEAR support
Message 147 of 198
Guru
Did you try right-clicking ("save as") and adding a .bin extension to the file name?
Message 148 of 198
pec
Is this genuine? Has anyone tried it?
Message 149 of 198
hauser1
Maybe I was a bit to subtle with my post, on "4/22/2013 11:29:00 PM" I was asked to download 5.3.8-T20 and again on "5/13/2013 4:23:00 AM" I was asked to download 5.3.8-T20... didn't help the first time I downloaded/applied the firmware doubt it would help again now.
Message 150 of 198
Top Contributors
Discussion stats
Announcements
