Orbi WiFi 7 RBE973
Reply
Netgear ReadyNAS 312 / SSD / raid 0 problem
nasman14
Follower
Hi people - this is my first post on this forum 🙂
My system: Netgear-ReadyNAS-312 with two SSDs on raid0:
-Samsung SSD 840 EVO 500GB (MZ-7TE500BW)
-APPLE SSD TS512C 500GB
this configuration worked perfectly and i used it as a 1TB NAS
After 4 months I wanted to enlarge the volume replacing the Samsung 500GB MZ-7TE500B with a Samsung SSD 840 EVO 1TB (MZ-7TE1T0BW).
I expected to obtain a volume from 1,5TB but ReadyNAS generates a raid0 volume with just 920 GB...
What I'm doing wrong... 😞
Thanx
Julian
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: Netgear ReadyNAS 312 / SSD / raid 0 problem
You should create a separate volume for each SSD. We use the capacity of the smallest one for spanned volumes (which I don't recommend as if either SSD fails all data is lost).
Message 2 of 5
Guru
There's certainly no performance gain in spanning SSDs.
Message 3 of 5
TeknoJnky
Hero
no one answered his question;
You can not expand raid 0 arrays.
Message 4 of 5
Jedi_Knight
Tutor
I had seen that some of the RN 3XX/5XX will stuck in OS reboot with 6.1.9 code when SSD drive installed. From my past experiences, I had to power off the system from rocker switch behind the box and power back on to boot normal.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1818 views
  • 0 kudos
  • 5 in conversation
Announcements
