× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
No access to Frontview Case #20726536
railstop1
I have opened a case for this. I am unable to figure this out. PHP was installed but did not work. the add on was removed and now there is no frontview access. I can access the files no problem.
Message 1 of 8
chirpa
Luminary
Re: No access to Frontview Case #20726536
They will most likely ask you to put it in Tech Support mode; http://www.readynas.com/kb/faq/boot/how ... _boot_menu
Message 2 of 8
atanas2
Hi railstop,
Try OS-reinstall. This is the link how to do it. http://www.readynas.com/kb/faq/boot/how ... plus_pro_6
Message 3 of 8
railstop1
Hi, I did OS reinstall yesterday with no progress. I still cannot access frontview, yet i can access files.
Message 4 of 8
mdgm-ntgr
NETGEAR Employee Retired
I suppose you don't have SSH access?
Message 5 of 8
railstop1
Not now. I did before. 😞
Message 6 of 8
mdgm-ntgr
You will need to put the NAS in tech support mode. Since you can still access your files at the moment it should be a relatively easy issue for them to fix.
Message 7 of 8
railstop1
Thanks Chirpa and mdgm. I kind of figured that too. Never had to use Tech Mode. i'll put it in it now so when I'm away tomorrow It'll be ready.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1452 views
  • 0 kudos
  • 4 in conversation
Announcements
