× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
No admin page NAS 102 even after ssh
Abishek22
root@NetgearNAS:/apps# ls
DO_NOT_DELETE  plexmediaserver	surveillance  transmissionr6
root@NetgearNAS:/apps# apt-get purge surveillance
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
root@NetgearNAS:/apps# service surveillance stop
surveillance: unrecognized service
root@NetgearNAS:/apps# cd /apps/surveillance
root@NetgearNAS:/apps/surveillance# rm 090-surveillance.conf
rm: cannot remove `090-surveillance.conf': No such file or directory
root@NetgearNAS:/apps/surveillance# cd /etc/apache2/sites-enabled
root@NetgearNAS:/etc/apache2/sites-enabled# rm 090-surveillance.conf
root@NetgearNAS:/etc/apache2/sites-enabled# ls
000-fv-http  000-fv-https
root@NetgearNAS:/etc/apache2/sites-enabled# cd /etc/apache2/sites-available
root@NetgearNAS:/etc/apache2/sites-available# ls
default  default-ssl  fv-http  fv-http-admin  fv-https
root@NetgearNAS:/etc/apache2/sites-available# cd /etc/apache2/sites-enabled
root@NetgearNAS:/etc/apache2/sites-enabled# /etc/init.d/apache2 start
[....] Starting apache2 (via systemctl): apache2.serviceJob failed. See system journal and 'systemctl status' for details.
 failed!
root@NetgearNAS:/etc/apache2/sites-enabled# systemctl status readynasd
readynasd.service - ReadyNAS System Daemon
	  Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
	  Active: active (running) since Sat, 03 Sep 2016 18:42:25 +0530; 19min ago
	Main PID: 3493 (readynasd)
	  Status: "Start Main process"
	  CGroup: name=systemd:/system/readynasd.service
		  └ 3493 /usr/sbin/readynasd -v 3 -t
Sep 03 18:59:19 NetgearNAS msmtpq[9513]: mail for [ -C /etc/msmtprc Drabishe...l
Sep 03 18:59:20 NetgearNAS readynasd[3493]: Detected increasing ATA error co....
Sep 03 18:59:23 NetgearNAS msmtpq[9532]: mail for [ -C /etc/msmtprc Drabishe...l
Sep 03 18:59:23 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, p...)
Sep 03 19:01:20 NetgearNAS readynasd[3493]: Detected increasing ATA errors o...]
Sep 03 19:01:20 NetgearNAS readynasd[3493]: Detected increasing ATA error co....
Sep 03 19:01:25 NetgearNAS msmtpq[10010]: mail for [ -C /etc/msmtprc Drabish...l
Sep 03 19:01:25 NetgearNAS readynasd[3493]: Detected increasing ATA error co....
Sep 03 19:01:28 NetgearNAS msmtpq[10025]: mail for [ -C /etc/msmtprc Drabish...l
Sep 03 19:01:28 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, p...)
root@NetgearNAS:/etc/apache2/sites-enabled# systemctl status apache2
apache2.service - The Apache HTTP Server
	  Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
	  Active: failed (Result: resources) since Sat, 03 Sep 2016 18:57:55 +0530; 4min 18s ago
	 Process: 9093 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=0/SUCCESS)
	 Process: 8954 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
	  CGroup: name=systemd:/system/apache2.service
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of Allow...onf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of Allow...onf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: apache2: Could not reliably determine the server's ful...Name
Sep 03 18:57:44 NetgearNAS apache2[9093]: [warn] RSA server certificate CommonName (CN) `nas-34-...me!?
root@NetgearNAS:/etc/apache2/sites-enabled# journalctl -a | grep apache2 | tail -n 20
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 7 of /etc/frontview/apache/Shares.conf.
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 23 of /etc/frontview/apache/Shares.conf.
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 46 of /etc/frontview/apache/Shares.conf.
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 4 of /etc/frontview/apache/apps-https.conf.
Sep 03 18:57:43 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 3 of /apps/surveillance/https.conf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 46 of /etc/frontview/apache/Shares.conf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 4 of /etc/frontview/apache/apps-https.conf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: [Sat Sep 03 18:57:43 2016] [warn] Useless use of AllowOverride in line 3 of /apps/surveillance/https.conf.
Sep 03 18:57:44 NetgearNAS apache2[9093]: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.1.4 for ServerName
Sep 03 18:57:44 NetgearNAS apache2[9093]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 18:57:44 NetgearNAS systemd[1]: PID file /var/run/apache2.pid not readable (yet?) after start.
Sep 03 18:57:55 NetgearNAS systemd[1]: apache2.service never wrote its PID file. Failing.
Sep 03 18:57:55 NetgearNAS systemd[1]: Unit apache2.service entered failed state.
Sep 03 18:57:55 NetgearNAS systemd[1]: Triggering OnFailure= dependencies of apache2.service.
Sep 03 18:57:55 NetgearNAS apache2[9136]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 18:57:55 NetgearNAS apache2[9156]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 18:57:55 NetgearNAS apache2[9136]: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.1.4 for ServerName
Sep 03 18:57:58 NetgearNAS apache2[9156]: [error] server reached MaxClients setting, consider raising the MaxClients setting
root@NetgearNAS:/etc/apache2/sites-enabled# journalctl -a | grep readynasd | tail -n 20
Sep 03 18:55:01 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3370] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1553 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:55:05 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3370] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1553 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:55:11 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (37, 136, 6561, 62, 194)
Sep 03 18:57:08 NetgearNAS readynasd[3493]: Detected increasing ATA errors on disk 2 [3370, 3381]
Sep 03 18:57:08 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3381] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1554 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:57:12 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3381] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1554 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:57:16 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (37, 136, 6561, 62, 194)
Sep 03 18:58:26 NetgearNAS readynasd[3493]: Antivirus scanner definition file was updated to 201609031202.
Sep 03 18:59:15 NetgearNAS readynasd[3493]: Detected increasing ATA errors on disk 2 [3381, 3396]
Sep 03 18:59:15 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3396] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1555 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:59:20 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3396] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1555 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 18:59:23 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (37, 136, 6561, 62, 194)
Sep 03 19:01:20 NetgearNAS readynasd[3493]: Detected increasing ATA errors on disk 2 [3396, 3408]
Sep 03 19:01:20 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3408] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1556 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:01:25 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3408] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1556 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:01:28 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 136, 6561, 62, 194)
Sep 03 19:03:26 NetgearNAS readynasd[3493]: Detected increasing ATA errors on disk 2 [3408, 3420]
Sep 03 19:03:26 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3420] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1557 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:03:31 NetgearNAS readynasd[3493]: Detected increasing ATA error count: [3420] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1557 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:03:34 NetgearNAS readynasd[3493]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 136, 6561, 62, 194)
 failed!
root@NetgearNAS:/etc/apache2/sites-enabled# cd /etc/apache2/sites-enabled
Can someone help me , have tried all these commands to get my admin page back with no luck
have already removed 090-***** .conf files
the NAS is accessible via SMB,but no Admin page
Model: RN102|ReadyNAS 100 Series
Message 1 of 14
mdgm-ntgr
NETGEAR Employee Retired
Re: No admin page NAS 102 even after ssh
Which firmware are you running?
The issue where an app uninstall could lead to Apache failing to start was fixed long ago and I don't think that is why the service crashed.
Looks like you have at least one failing disk. That ATA error count is huge.
Do you have a backup?
Message 2 of 14
Abishek22
Yes, i know there is a huge ATA count and probably the disk is going to fail. i do have a backup. no a problem if the HDD fails.
But how do i get the ADMIN page backup
on ReadyNASOS 6.4.2
root@NetgearNAS:~# systemctl status apache2
	  Active: failed (Result: resources) since Sat, 03 Sep 2016 19:25:51 +0530; 7min ago
	 Process: 4517 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=0/SUCCESS)
	 Process: 4345 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
Message 3 of 14
Abishek22
 output of
# df -h
# btrfs fi show
# btrfs fi df /data
	  Active: failed (Result: resources) since Sat, 03 Sep 2016 19:25:51 +0530; 10min ago
root@NetgearNAS:~# journalctl -a | grep apache2 | tail -n 20
Sep 03 19:25:47 NetgearNAS systemd[1]: PID file /var/run/apache2.pid not readable (yet?) after start.
Sep 03 19:25:51 NetgearNAS systemd[1]: apache2.service never wrote its PID file. Failing.
Sep 03 19:25:51 NetgearNAS systemd[1]: Unit apache2.service entered failed state.
Sep 03 19:25:51 NetgearNAS systemd[1]: Triggering OnFailure= dependencies of apache2.service.
Sep 03 19:25:47 NetgearNAS apache2[4517]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 19:25:51 NetgearNAS apache2[4517]: [Sat Sep 03 19:25:47 2016] [warn] Useless use of AllowOverride in line 7 of /etc/frontview/apache/Shares.conf.
Sep 03 19:25:51 NetgearNAS apache2[4517]: [Sat Sep 03 19:25:47 2016] [warn] Useless use of AllowOverride in line 23 of /etc/frontview/apache/Shares.conf.
Sep 03 19:25:51 NetgearNAS apache2[4517]: [Sat Sep 03 19:25:47 2016] [warn] Useless use of AllowOverride in line 46 of /etc/frontview/apache/Shares.conf.
Sep 03 19:25:51 NetgearNAS apache2[4517]: [Sat Sep 03 19:25:47 2016] [warn] Useless use of AllowOverride in line 4 of /etc/frontview/apache/apps-https.conf.
Sep 03 19:25:51 NetgearNAS apache2[4517]: [Sat Sep 03 19:25:47 2016] [warn] Useless use of AllowOverride in line 3 of /apps/surveillance/https.conf.
Sep 03 19:25:51 NetgearNAS apache2[4517]: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.1.4 for ServerName
Sep 03 19:25:51 NetgearNAS apache2[4559]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 19:25:51 NetgearNAS apache2[4559]: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.1.4 for ServerName
Sep 03 19:25:51 NetgearNAS apache2[4580]: [warn] RSA server certificate CommonName (CN) `nas-34-45-56.local' does NOT match server name!?
Sep 03 19:25:55 NetgearNAS apache2[4580]: [error] server reached MaxClients setting, consider raising the MaxClients setting
root@NetgearNAS:~# journalctl -a | grep readynasd | tail -n 20
Sep 03 19:27:29 NetgearNAS readynasd[3542]: Detected increasing ATA errors on disk 2 [3500, 3513]
Sep 03 19:27:29 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3513] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1563 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:27:33 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3513] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1563 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:27:36 NetgearNAS readynasd[3542]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 137, 6561, 63, 195)
Sep 03 19:29:34 NetgearNAS readynasd[3542]: Detected increasing ATA errors on disk 2 [3513, 3524]
Sep 03 19:29:34 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3524] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1564 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:29:37 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3524] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1564 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:29:40 NetgearNAS readynasd[3542]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 137, 6561, 63, 195)
Sep 03 19:31:38 NetgearNAS readynasd[3542]: Detected increasing ATA errors on disk 2 [3524, 3536]
Sep 03 19:31:38 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3536] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1565 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:31:43 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3536] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1565 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:31:46 NetgearNAS readynasd[3542]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 137, 6561, 63, 195)
Sep 03 19:33:42 NetgearNAS readynasd[3542]: Detected increasing ATA errors on disk 2 [3536, 3548]
Sep 03 19:33:42 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3548] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1566 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:33:45 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3548] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1566 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:33:48 NetgearNAS readynasd[3542]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 137, 6561, 63, 195)
Sep 03 19:35:46 NetgearNAS readynasd[3542]: Detected increasing ATA errors on disk 2 [3548, 3560]
Sep 03 19:35:46 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3560] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1567 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:35:49 NetgearNAS readynasd[3542]: Detected increasing ATA error count: [3560] on disk 2 (Internal) [WDC WD40EFRX-68WT0N0, WD-WCC4E1NJJTH9] 1567 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 03 19:35:52 NetgearNAS readynasd[3542]: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (38, 137, 6561, 63, 195)
root@NetgearNAS:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
tmpfs            10M  4.0K   10M   1% /dev
/dev/md0        3.7G  806M  2.7G  23% /
tmpfs           249M  4.0K  249M   1% /dev/shm
tmpfs           249M  1.6M  247M   1% /run
tmpfs           249M     0  249M   0% /sys/fs/cgroup
tmpfs           249M     0  249M   0% /media
/dev/md127      3.7T  1.1T  2.6T  30% /data
/dev/md127      3.7T  1.1T  2.6T  30% /apps
/dev/md127      3.7T  1.1T  2.6T  30% /home
tmpfs            50M     0   50M   0% /var/replicate/shm
/dev/md127      3.7T  1.1T  2.6T  30% /var/ftp/DivyaDocuments
/dev/md127      3.7T  1.1T  2.6T  30% /var/ftp/HDVideo
/dev/md127      3.7T  1.1T  2.6T  30% /var/ftp/Vid
/dev/md127      3.7T  1.1T  2.6T  30% /run/nfs4/data/DivyaDocuments
/dev/md127      3.7T  1.1T  2.6T  30% /run/nfs4/data/HDVideo
/dev/md127      3.7T  1.1T  2.6T  30% /run/nfs4/data/Vid
/dev/md127      3.7T  1.1T  2.6T  30% /run/nfs4/home
root@NetgearNAS:~# btrfs fi show
Label: '0e344556:data'  uuid: e02b70d6-4338-4c2b-bddc-2f16d345f24e
	Total devices 1 FS bytes used 1.07TiB
	devid    1 size 3.63TiB used 1.17TiB path /dev/md127
btrfs-progs v4.1.2
root@NetgearNAS:~# btrfs fi df /data
Data, single: total=1.17TiB, used=1.07TiB
System, DUP: total=8.00MiB, used=192.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=1.00GiB, used=148.50MiB
Metadata, single: total=8.00MiB, used=0.00B
GlobalReserve, single: total=64.00MiB, used=0.00B
root@NetgearNAS:~#
Message 4 of 14
mdgm-ntgr
Try e.g.
# systemctl restart apache2
Message 5 of 14
Abishek22
Last login: Sat Sep  3 19:33:06 2016 from 192.168.1.8
eroot@NetgearNAS:~# systemctl restart apache2
root@NetgearNAS:~#
Message 6 of 14
Abishek22
Have downloaded the LOGS
Message 7 of 14
mdgm-ntgr
Well you could send the zip file in (see the Sending Logs link in my sig)
Message 8 of 14
Abishek22
Sent you the logs
Message 9 of 14
mdgm-ntgr
Well you have SSH enabled and your disk is failing badly.
I can see you still have some packages installed such as PHP, MySQL, Transmission etc.
Message 10 of 14
Abishek22
Yes i have a backup.
i have those installed but just to try them out. i don't need any of it. i don't mind uninstalling and removing everything to get it working again. how do i uninstall apps via ssh
Message 11 of 14
mdgm-ntgr
Not sure whether those apps would have caused the problem or not. It would seem unlikely, but you can use
# apt-get purge <packagename>
to purge a package. The order you remove packages can matter and entering the right package name.
Message 12 of 14
Abishek22
Got tired of waiting for a solution
1)Found  a replacement hard drive and did a factory reset wiping all data.Did firmware upgrade to 6.5
2)Admin page now works
3)Lost data
4)At least it works.
5)Thank you mgdm
6)Will stick to buying and using only Synology NAS from now on and not try to save money and buy Netgear,lesson learned.
Message 13 of 14
mdgm-ntgr
You can hardly expect a system with a bad disk and with that the only disk to operate well.
You would find you'd have lots of problems in that situation with any brand.
You could have backed up your data if you could still access it but chose not to. If you could not access your data we do have data recovery services that we sell which you could have chosen to take advantage of.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2792 views
  • 0 kudos
  • 2 in conversation
Announcements
