× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
OS 6.4 Experience on Legacy Hardware
Guru
Re: OS 6.4 Experience on Legacy Hardware
Maybe try installing 6.4.1-RC1, and see if that helps.  If it doesn't, you might need to try a factory reset.
Message 26 of 37
Equinox1
Guide
I have a stock Pro 6 with 6x2tb running 6.4.0. The SMB disconnects from the mac, and the unit freezes every 2 weeks or so. I guess there are still some rough edges in this firmware.
I also have a heavily modified Pro 6 (Q6600 and 4gb RAM) with 4x3tb running 6.4.0. No macs on this network so I dont know about the SMB shares on this one. And I had 1 freeze so far on this one since the update.
I appreciate the evolution in features of the OS, but we could definitely use some more stability.
Message 27 of 37
paalj
Hi,
thanks.
I have tried both RC1 and RC3, but it didn't get any better. I did a factory reset with RC3 and that did the trick 🙂
br
Paal
Message 28 of 37
viperhansa
Virtuoso
Hi All!
Anyone that have upgrade your 6.4.0 to 6.4.1 yet?
Any comments or issues?
regards
Hans
Message 29 of 37
Equinox1
Guide
I upgraded yesterday. So far, so good.
Eventless upgrade, on 2 boxes.
Message 30 of 37
Supertramp11
Luminary
Compared with 6.3.5 on a PRO 6: are the fans working equally well?
Message 31 of 37
viperhansa
Virtuoso
Me personally have no problems with the fans.
running 6.4.0 on pro 6.
Message 32 of 37
Supertramp11
Luminary
Thanks.
Unfortunately there are also less positive experiences:
https://community.netgear.com/t5/Using-your-ReadyNAS/CPU-temp-on-PRO-6-pioneer-edition-on-os-6-0-6-4...
There are maybe differences between a PRO 6 pioneer versus business edition???
Message 33 of 37
viperhansa
Virtuoso
Thanks.
I'm running the Pro 6 business version...
System AVG: 61 degrees celsius
CPU AVG: 44 degrees celsius
( i have a relative high ambient temperature, around 23-24 degrees)
// Hans
Message 34 of 37
Supertramp11
Luminary
On my PRO 6 business edition with 4 disks, cpu = 33 degrees and system = 54 degrees in an 21-22 degrees room running for 12 hrs now.
Seems like there is a difference between 6.3.5 and 6.4.0.
Message 35 of 37
Equinox1
Guide
For me, in the heavily modified machine (Q6600, 4Gb RAM, exotic fans, etc...) 45 CPU, 60 System are normal numbers... The disks run between 32-42 degrees....
The fans vary from 900 to 1500 RPMs.
On the 'stock' Pro6 I have 1-2 degrees less on average... but heavily dependent on load. When the disks start the monthly balancing, it sounds like I have the Concorde in the house... 😄
Message 36 of 37
Equinox1
Guide
Question to the Netgear guys... where is the 'system' temperature coming from? As another mentioned before, my dashboard says I have 60C degrees, but I have no real world indication of such temperature.
Message 37 of 37
Top Contributors
Discussion stats
Announcements
