- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OS X Filenames - backup failure - containing characters like / > ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Backup jobs fail presumably because certain OS X filennames can't be copied.
For example original filename:
.AC33E0B7-5909-458C-8A1C-0ECA51A0EA8B/ABSubscriptionRecord.abcds
The backup job completes with a failure - log says:
Failed to copy file '/data/Documents/users-imac/beate/Library/Application Support/AddressBook/Metadata/.AC33E0B7-5909-458C-8A1C-0ECA51A0EA8B:ABSubscriptionRecord.abcds' (error: No such file or directory)!
Although SMB and AFP protocol are switched on backup jobs fail, probably because the files contain certain characters that are allowed under OS X but maybe not unnder ReadyOS:
"/" "?" ">" It seems that filenames containing these characters are rejected?
If these files are copied by drag & drop the characters are replaced by "_", but when using a backup job they just completely fail.
So it is an nuisance if you can't rely on the backup jobs and filenames allowed under OS X fail to be copied / backed up onto a ReadyNAS
Any ideas, solutions or ReadyOS-Updates to solve these filename issues?
Yours NAS-SAN-NAS
Config.: ReadyNAS 316 24 TB, Firmware 6.4.2; OSX 10.9.5 - intending to back up data from MacbookPro, Imac and external drives
P.S.
I know that with TimeMachine these files can be backed up onto ReadyNAS. But that's beside the point as I just want to back up safely Data from Data-Partitions or attached external drives with filenames allowed under OS X!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OS X Filenames - backup failure - containing characters like / > ?
I doubt there is a perfect solution. Apple recommends a "best practice" of avoiding those characters in file names ( https://support.apple.com/en-us/HT202808 ). Though I think in your example the issue is likely the :
I suppose the backup could do the same character mapping as a copy, but wouldn't that cause issues on the restore?
You could try backing up to an iscsi lun formatted as HFS+, - which would require the backup to run on the mac, not the NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem is that the PC needs an "iSCSI initiator". Windows has that built-in, but the mac does not.
Here are two you could try for free - kernsafe's free version isn't time-limited, so maybe try that first???:
http://www.kernsafe.com/product/iscsi-san-macos/license-compares.aspx
http://www.studionetworksolutions.com/globalsan-iscsi-initiator/
There might be others, hopefully folks using iSCSI on OSX will chime in.
