× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
OS6 NOW WORKS ON X86 LEGACY
DownloaderUK
Hello all.
I am looking to upgrade to OS6 and although l have found various links here, l am looking for a clear start to finish guide please with all links to the correct files & fw. I am computer literate, but l have never done this sort of thing before and need to ensure it does not go wrong of brick up.
All help would be hugely appriciated. PS, instead of creating this new thread, l wanted to reply to previous ones but they were locked.
Thanks in advance.
Bushpig
Model: RNDP600E (ReadyNAS Pro Pioneer Edition)|ReadyNAS Pro Pioneer Edition|EOL
Message 1 of 10
Guru
Re: OS6 NOW WORKS ON X86 LEGACY
The steps are
(Optionally) make sure the latest BIOS is installed before you do the conversion.  To do this you install  http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS.  Do this after you backup the NAS.  This isn't necessary, but if you so want to update the bios it is easiest to do it prior to converion
Basic instructions for the conversion itself are
  1. BACKUP, BACKUP, BACKUP
  2. Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
  3. Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
  4. After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
  5. Go through the setup process on the converted NAS
  6. Update the NAS to the current OS 6 (check for updates will work).
  7. Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration.  There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
If you do decide to convert the Pro, then you should also consider increasing the RAM.  Shipping OS-6 NAS have at least 2 GB of RAM, your Pro only has 1 GB.  It will work, but it would be sensible to match the resources in the currently shipping NAS.  The upgrade is inexpensive, and is simple to do.
Message 2 of 10
DownloaderUK
StephenB,
Thank you for the reply. Do you have a guide on how to upgrade the RAM to 2GB by chance?
Thank you
Message 3 of 10
Guru
No, but it's not difficult.  You need to remove the skin on the left side of the chassis (facing the front of the unit), and you'll see the RAM slots.  In my case, only one of the two slots was used.
You want pc6400 ddr2 800mhz 240 pin DIMM (non-ECC, unbuffered).   https://www.crucial.com/memory/ddr2/ct25664aa800 is one option that should work.
Message 4 of 10
Sandshark
Sensei
Since the unit doesn't use dual-channel RAM, you can upgrade the empty slot to more if you like with no speed penalty for the banks being mismatched.  Up to 2GB sticks are available cheap.  4GB 2Rx8 ("low density", as opposed to 2Rx4 "high density") are needed and are not as common and the board can't support more than 8GB total.
Message 5 of 10
DownloaderUK
I downloaded ssh and did an ls command. Here is the output. Can you advise what you see here? I am concerned as l have allot of folders that appear to have these ?? folders but l cannot cd into them. Any advice?
Message 6 of 10
Guru
I'm not sure where you are here.
  • Have you converted to OS-6?
  • Did you log into the NAS using root as the username (using the admin password)?
Your directory list doesn't look right.  This is what I see on my Pro-6 (recently converted to OS-6)
root@PRO://# cd //
root@PRO://# ls -al
total 64
drwxr-xr-x   1 root  root   168 Nov 28 06:48 .
drwxr-xr-x   1 root  root   168 Nov 28 06:48 ..
-rw-r--r--   1 root  root     0 Nov 28 06:48 1
drwxrwxr-x   1 root  root   168 Nov 25 12:04 apps
drwxr-xr-x   1 root  root  1330 Nov 24 16:13 bin
drwxr-xr-x   1 root  root     0 May 21  2012 boot
drwxr-xr-x   1 root  root   178 Nov 25 12:01 data
drwxr-xr-x  17 root  root  3560 Nov 24 16:14 dev
drwxr-xr-x   1 root  root  2516 Nov 26 16:01 etc
drwxr-xr-x   1 root  root    54 Nov 24 16:12 frontview
drwxr-xr-x   1 admin admin   10 Nov 24 16:13 home
drwxr-xr-x   1 root  root   462 Nov 24 16:12 lib
drwxr-xr-x   1 root  root    40 Nov 24 16:12 lib64
drwxr-xr-x   1 root  root     0 Jun  4  2012 media
drwxr-xr-x   1 root  root     0 Jan 25  2016 mnt
drwxr-xr-x   1 root  root    72 Nov 24 16:13 opt
dr-xr-xr-x 196 root  root     0 Nov 24 16:11 proc
drwx------   1 root  root    64 Nov 24 16:36 root
drwxrwxr-x  23 root  admin  820 Nov 28 06:48 run
drwxr-xr-x   1 root  root  2590 Nov 24 16:13 sbin
drwxr-xr-x   1 root  root     0 Jun  4  2012 srv
dr-xr-xr-x  12 root  root     0 Nov 24 16:13 sys
drwxrwxrwt   1 root  root    94 Dec  2 10:17 tmp
drwxr-xr-x   1 root  root    70 Nov 24 16:12 usr
drwxr-xr-x   1 root  root   146 Nov 24 16:13 var
root@PRO://#
Message 7 of 10
Sandshark
Sensei
That looks like an OS4.2.x top level directory with a lot of stuff added that should not be there,  Something or somebody is (or at least was) adding things to the OS partition that should not be there.  Maybe it was due to an improperly mounted USB drive and things intended for it went to top level?  The files/directories with the ?? are likely unicode, which your SSH program doesn't understand.
Whether you are sticking with 4.2.x or upgrading to 6.x, a factory default definately seems in order.
Message 8 of 10
AdrianoBolzani
It worked flawlessly. Thank you.
The restoring has been painful. 5Tb will take over 7 days with a lot of Re DOs because some erros on file's names or something similar.
Safari and Chrome still show unsecured access. Any suggestion to fix it?
Regards
Message 9 of 10
Guru
That's because the NAS is using a self-signed certificate.  The simplest thing to do is just click though it.  The connection is still encrypted (despite the warning).
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1904 views
  • 6 kudos
  • 4 in conversation
Announcements
