× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
ATCIS
Tutor
Re: OS6 now works on x86 Legacy WARNING: NO NTGR SUPPORT!
Iridabike wrote:
That's reduced it to around 100 hours -Thanks. Still seems a long time though.
So has your RAID Array re-sync finished yet? It looks like your NAS is configured in a similar fashion to the one I have been stress testing with OS6. When I expanded my array from 5 drives to 6, the process took approximately 32 hours.
Please report back when yours finishes. I'd be curious to hear how long yours took.
P.S.: What type of drives are you using?
Message 551 of 1,275
Iridabike
No its still syncing with another 70+ hours to go. The drives are WD 2TB reds. I went from raid 5 to 6. I have a 6700 processor with 4GB of ram - cant believe the sync can take so long.
My next step is to add another to expand my storage. Probably do this when I go away....
Message 552 of 1,275
ATCIS
Tutor
ReadyNAS Alert Message
Okay folks here's a new one:
About and hour ago I rebooted a ReadyNAS Ultra 4 with four 1TB drives. I did this about 30 minutes after deleting a share from the GUI that had about 80% of the data volume's files in it. I rebooted because the pie charts and graphs in the GUI were not reflecting any change of available free space. After the reboot, the GUI did reflect quite a bit more free space in the data volume, but now every 10 minutes I'm getting sent an E-Mail that says:
System volume 'root' usage is 91 %. This condition should not occur in normal conditions. Please contact technical support.
System volume 'root' usage is 100 %. This condition should not occur in normal conditions. Please contact technical support.
System volume 'root' usage is 99 %. This condition should not occur in normal conditions. Please contact technical support.
Etc., etc., etc. over and over.
From the command line I ran:
df
which resulted in
Filesystem      1K-blocks      Used  Available Use% Mounted on
rootfs 4192192 3505532 48140 99% /
tmpfs 10240 4 10236 1% /dev
/dev/md0 4192192 3505532 48140 99% /
tmpfs 2021468 0 2021468 0% /dev/shm
tmpfs 2021468 4544 2016924 1% /run
tmpfs 2021468 0 2021468 0% /sys/fs/cgroup
tmpfs 2021468 0 2021468 0% /media
/dev/md127 2915731968 866720844 1933903372 31% /data
/dev/md127 2915731968 866720844 1933903372 31% /home
/dev/md127 2915731968 866720844 1933903372 31% /apps
Help! I have no clue how to troubleshoot this one.
Thanks in advance!
Message 553 of 1,275
mdgm-ntgr
NETGEAR Employee Retired
Your 4GB OS partition is full.
You can use the du command to find out what's filling it up.
You could start by doing e.g.
# du -csh /var/log
Message 554 of 1,275
ATCIS
Tutor
mdgm wrote:
du -csh /var/log
Results in:
121M	/var/log
121M total
Pardon my ignorance, but that means nothing to me. . . :oops:
Message 555 of 1,275
mdgm-ntgr
That means 121MB of the 4GB is in use in /var/log, so the problem is somewhere else. There's probably a folder somewhere with roughly 3GB in use that is on the OS partition (not on your data volume(s)).
Message 556 of 1,275
ATCIS
Tutor
Is there some sort of filter, option, or pipe that I can use in conjunction with "du" that would give me a summary list of the directory tree from largest to smallest (or vice versa) so I can figure out what directory to start looking in?
EDIT: Never mind. I think I figured that one out on my own. I used:
du -h --max-depth=1 /
Which resulted in:
7.1M	/bin
0 /boot
4.0K /dev
6.4M /etc
72K /home
21M /lib
4.0K /lib64
0 /media
0 /mnt
5.0M /opt
0 /proc
24K /root
4.5M /run
8.2M /sbin
0 /selinux
0 /srv
0 /sys
52K /tmp
444M /usr
2.8G /var
18M /frontview
2.8T /data
928K /apps
2.8T /
It looks like there is something going on in /var. . .
Message 557 of 1,275
super_poussin
Virtuoso
find {/path/to/directory} -type f -size +{file-size-in-kb}k -exec ls -lh {} \; | awk '{ print $8 ": " $5 }'
Message 558 of 1,275
super_poussin
Virtuoso
or
find . -type f -print0 | xargs -0 du -s | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
Message 559 of 1,275
mdgm-ntgr
Yes it is in /var, just not in /var/log
Let us know what filled it up.
Message 560 of 1,275
ATCIS
Tutor
So this particular ReadyNAS is running as a Network Video Recorder (Not NETGEAR's prohibitively expensive one). All the actual video gets deposited into /data/NVR/Video/*.* so not problem there. However, the NVR Database (MongoDB) resides in '/var/lib/nvr/db/' and '/var/lib/nvr/db/journal'.
So my dilemma now is what do I do? Can I somehow move the database somewhere else where there is more room? Can the rootfs be enlarged to say 8GB's from 4GB's. I mean this database is only going to get bigger over time, and now that I'm at 99%, there is no more room for it to grow.
Anyone got any ideas?
Message 561 of 1,275
super_poussin
Virtuoso
perhaps a symlink ?
you move the database somewhere with space in /data/xxxx then to a symling to the original place
Message 562 of 1,275
mdgm-ntgr
Or does the NVR software have a configuration file allowing you to specify the location to store the DB so you could specify a path e.g. /data/NVR/database
Message 563 of 1,275
ATCIS
Tutor
super-poussin wrote:
perhaps a symlink ?
Yeah I was kind'a thinking the same thing. Okay now I have to learn how to do that in Linux. A Google'ing I go, a Google'ing I go, high ho the dairy'o a Google'ing I go!
:google:
Oh and by the way, many thanks to super-poussin for these:
I didn't use them this time but I'm sure I will in the future. . .
Message 564 of 1,275
super_poussin
Virtuoso
mkdir -p /data/nvr/lib/nvr/db/
mv /var/lib/nvr/db/* /data/nvr/lib/nvr/db/
rm -r /var/lib/nvr
ln -s /data/nvr/lib/nvr /var/lib/
ps : make a ls -al /var/lib to check ownaer and rights you have on nvr directory to apply them again
Message 565 of 1,275
ATCIS
Tutor
Thanks again to all of you that replied with helpful suggestions. :worship: The command 'df' now shows:
root@ReadyNAS-U4:/# df
rootfs 4192192 957856 2577672 28% /
/dev/md0 4192192 957856 2577672 28% /
tmpfs 2021468 4540 2016928 1% /run
/dev/md127 2915731968 869288756 1931342132 32% /data
/dev/md127 2915731968 869288756 1931342132 32% /home
/dev/md127 2915731968 869288756 1931342132 32% /apps
So I went from a 'rootfs' at 99% down to 28%. So that I might get a better idea as to what is normal, I'd like to hear some feedback to as to what some of you other folks running OS6 have for 'rootfs' percent of utilization.
Cheers!
Message 566 of 1,275
mdgm-ntgr
28% is fine. I have a system that isn't doing much at the moment which has an OS partition which is 15% full.
Message 567 of 1,275
spirit11
I am having ReadyNAS 2100 and i have 4 HDD. 2 - 2TB in bay1 and bay2. 2-1TB in bay3 and bay4.
From the UI, i can see only two 2TB HDD from system -> Volumes.
Please look at my "cat /proc/mdstat"
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md126 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
2915731968 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md127 : active raid1 sda4[0] sdb4[1]
976622784 blocks super 1.2 [2/2] [UU]
md1 : active raid6 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1047936 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
4192192 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
and "df -h"
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 786M 2.6G 23% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 786M 2.6G 23% /
tmpfs 494M 0 494M 0% /dev/shm
tmpfs 494M 5.9M 488M 2% /run
tmpfs 494M 0 494M 0% /sys/fs/cgroup
tmpfs 494M 0 494M 0% /media
/dev/md126 3.7T 829G 2.7T 24% /data
/dev/md126 3.7T 829G 2.7T 24% /home
/dev/md126 3.7T 829G 2.7T 24% /apps
Please help me how i can recover the 2 - 1TB disk in the UI.
Message 568 of 1,275
noxius
Hey,
can anybody tell me how to downgrade from 6.0.8 to "old" 4 firmware, since my system is not running how it should.... (web interface is crashing very often and saying is offline... or plex is crashing after 3 min and is not reachable.....I did already twice reset but nothing helped...) I couldn´t find any deb file nor the version with usb is working since i cant run the exe file (says always I´m missing some files)....
any ideas?
thanks
Message 569 of 1,275
mdgm-ntgr
PM'd you a link. Note downgrading requires a factory reset.
Message 570 of 1,275
wli
Tutor
Tutor
I have a ultra 4, will os6 improve performance? Thanks.
Sent from my SGH-I747M using Tapatalk 2
Message 571 of 1,275
ATCIS
Tutor
What kind of performance? If you are asking about network performance, mine has been nearly identical. NFS file transfer speeds are slightly better but SMB slightly slower (by about 10% or so; barely noticeable). . .
Message 572 of 1,275
wli
Tutor
Tutor
How about iSCSI? Thanks.
Message 573 of 1,275
ATCIS
Tutor
How about iSCSI?
I have not personally tested iSCSI, but you might want to read this post: viewtopic.php?f=51&t=70133&p=399889&hilit=iSCSI#p399889
This guy apparently is having all kinds of issues with iSCSI. . .
Message 574 of 1,275
mangrove
Apprentice
Have they changed from using LIO to something else for iSCSI?
Message 575 of 1,275
Top Contributors
Announcements
