× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Password for Locked Hard Drives
pandabigman
Hi Support,
I have a problem on my ReadyNAS pro 6 HDD. My readynas pro can't access some hdd.
When i put these hdd on my desktop and power on. My PC will show Hard disk "xxxxxxxxxxxxxxxx" is protected by a password enter the password or press ESC to exit
How can i remove the password? I have 5/6 HDD as a same problem.
Best regards,
Terence Lo
Message 1 of 5
Guru
Re: Password for Locked Hard Drives
I've never had to do this, but there is an old thread that suggests the following:
For future reference, this should unlock the drives:
hdparm --security-unlock NETGEAR /dev/???
hdparm --security-disable NETGEAR /dev/???
So maybe try NETGEAR on the PC.
You can find hdparm for Windows, but the commands might not work there, since /dev/??? is an linux path.
Message 2 of 5
pandabigman
Hi StephenB,
Becuase these 5 HDD is same not working on my readynas pro6, the readynas have any telnet console to using the command?
Best regards,
Terence Lo
Message 3 of 5
Guru
It does support ssh.  Netgear can also unlock them remotely.  Perhaps a Netgear person here can help.
Message 4 of 5
mdgm-ntgr
NETGEAR Employee Retired
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3263 views
  • 0 kudos
  • 3 in conversation
Announcements
