× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104 Unable to access admin page - Firmware 6.7.3
mocoyn
Hi
After install the firmware 6.7.3 I can't access to admin page with the name of the NAS. I can only access with the IP.
Too, I've detected I can't access by FTP after install the firmware.
Any suggestion? Any idea?
Thanks
Model: RN104|ReadyNAS 100 Series
Message 1 of 15
Accepted Solutions
Skywalker
NETGEAR Expert
Re: RN104 Unable to access admin page - Firmware 6.7.4
"nas_home" is not a valid hostname, so you'll probably want to rename it to something like "nas-home".  See https://en.wikipedia.org/wiki/Hostname#Restrictions_on_valid_hostnames.
Message 12 of 15
All Replies
JennC
NETGEAR Employee Retired
Re: RN104 Unable to access admin page - Firmware 6.7.3
Hello mocoyn,
Does it still show on the RAIDar the hostname of the NAS? Can you stil also ping the hostname?
Message 2 of 15
mdgm-ntgr
Also, which web browser are you using?
Are any other services affected e.g. SMB?
Message 3 of 15
mocoyn
The hostname appear as my "nas_home" and when I try ping to this hostname, it respond correctly.
Appear the next text:
C:\Users\IBM_ADMIN>ping nas_home
Pinging nas_home [192.168.1.251] with 32 bytes of data
Reply from 192.168.1.251: bytes=32 time=1ms TTL=64
Reply from 192.168.1.251: bytes=32 time=2ms TTL=64
Reply from 192.168.1.251: bytes=32 time=3ms TTL=64
Ping statistics for 192.168.1.251:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 3ms, Average = 2ms
Message 4 of 15
mocoyn
I use Firefox and Chrome. And the service SMB is affected too 😞
This morning, I updgraded to 6.7.4 but the issue persist. I think the new firmware could solution the issue but not 😞
Message 5 of 15
Guru
Just to clarify:  I am thinking all services are working correctly when you use the IP address, but some are not connecting if you use the host name.
Is that a correct summary?
Message 6 of 15
mocoyn
It's correct the resume
Sorry, I push the button as "Accepted solution" by error 😞
Message 7 of 15
mdgm-ntgr
You may wish to see Self signed certificate error in Chrome 58
Can you download the logs?
Message 8 of 15
mocoyn
Sorry, I don't understand you. What have I do? Can you indicate me step a step?
Thanks
Message 9 of 15
Guru
Message 10 of 15
mocoyn
Thanks for the explanation.
I've send the logs request now, as indicate the url.
I'll expect answer.
Thanks
Message 11 of 15
Skywalker
NETGEAR Expert
Message 12 of 15
mocoyn
I've changed the hostname and I can access now, although my hostname (nas_home) had been working a few years before.. :S
Many thanks
Message 13 of 15
Guru
I'm not doubting that it worked before, but it is still illegal - it looks like it eventually caught up to you.
Message 14 of 15
Skywalker
NETGEAR Expert
Going forward, the admin GUI will prevent you from setting a bad hostname.  As OS compontents (in both Windows 10 and ReadyNASOS) continue to get updated over time, it's likely more things will cease to work with invalid hostnames.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 4405 views
  • 0 kudos
  • 5 in conversation
Announcements
