× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN214 ReadyNas is stuck on maxed out drive capacity
Redescort87
Follower
I have a readynas 214. I am using this as a backup solution and while backing up data it became full. I cleaned off space and tried again but the backups kept failing. I logged into the nas portal and noticed that all the volumes show red and still say they are full even though they are not. When I try to click on the volumes it just says they don't exist. I did find another article where a person was having the same issue and they said netgear helped them delete a log file and that fixed the issue but they didn't say what log file or where it was located. Any help with this would be appreciated. I have also included a screenshot of the volumes. nas 2.PNGnas.PNG
Model: RN214|4 BAY Desktop ReadyNAS Storage
Message 1 of 3
JohnCM_S
NETGEAR Employee Retired
Re: RN214 ReadyNas is stuck on maxed out drive capacity
Hi Redescort87,
Welcome to the Community!
Can you download the system logs and then provide it to us? You may check this link on how you can send it.
Message 2 of 3
JohnCM_S
Hi Redescort87,
Were you able to send the logs? You may just send it to us so we can further check the issue. Please check the link I have provided on the previous post on you can send it.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 865 views
  • 0 kudos
  • 2 in conversation
Announcements
