Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RNDP2000 hangs after loading initrd
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-17
08:26 AM
2013-07-17
08:26 AM
Hi,
I have a problem with a Pro2 unit, I've hooked up the serial console and it's looking like it hangs after loading the initrd, sometimes it reboots and then gets stuck in a boot/reboot loop, other times it just sits there.
I've used the reset buttons to run the memoy checks and thats fine, the other options for FactoryDefault or OSReinstall fail when trying to boot from an external flash device.
I have followed various instructions and managed to boot the unit from a flash drive created using the usbrecovery tool (http://home.bott.ca/webserver/?p=166) but I get the following error when booting with the backup button pressed.
I've also followed the notes here http://www.readynas.com/forum/viewtopic.php?f=64&t=70446 for trying the new u-boot but the flash drive created when following the notes doesnt work, I think I missed a step but cant work out the correct order.
All I really want is the unit to boot cleanly even if its from a fresh firmware install.
Anyone have any ideas where I might have gone wrong?
I have the exacy same symptons with a Duo V2 given to me from a family member so if I can get them both going it will be great.
Cheers
J
CPU : Intel(R) Atom(TM) CPU D525 @ 1.80GHz
Speed : 1.80 GHz
Press DEL to run Setup (F4 on Remote Keyboard)
Initializing USB Controllers .. Done.
1014MB OK
USB Device(s): 1 Storage Device
Auto-Detecting Pri Master..IDE Hard Disk
SYSLINUX 3.31 v1.07 Tue Feb 15 11:31:02 PST 2011
Copyright (C) 1994-2005 H. Peter Anvin
Debug Serial Port Enabled
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading
18
1B
NETGEAR
ReadyNAS
09/08/2010 ReadyNAS-ProUltra2 V1.4
kernel........................................................
Loading initrd.gz...........................Ready.
0110518 Copyright (C) 1994-2011 H. Peter Anvin et al
boot: Normal
Loading kernel.....
Loading initrd.gz.....ready.
ÿSearching for external boot flash device...Could not find external boot flash!
ERROR: Could not find external flash device!!
/bin/ash: can't access tty; job control turned off
Cheers
J
Message 1 of 1
Labels:
