× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Re: Lost all volume data on disks
Richter84
Sorry I'm new to this community and I can't find what the actual solution was to this issue.
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
kohdee remotely fixed Geeks_Alex's unit. Have you run into this also? If so, can you send in your logs (see the Sending Logs link in my sig)?
Message 2 of 7
Richter84
Yes when I got home from work all my disks were inactive.
I just sent in my logs.
Thanks
Message 3 of 7
mdgm-ntgr
I split your posts into a new thread as you have a different issue and you are not running beta firmware (so your posts don't belong in the beta forum).
Do you have a backup?
It looks like you added a disk and then during the resulting resync (which puts heavy stress on all disks) you ran into problems.
Message 4 of 7
Richter84
No I don't have an additional back up. So the ready as can't handle adding additional disks?
Message 5 of 7
Guru
He is suggesting that one of your disks failed during the resync.
Message 6 of 7
mdgm-ntgr
Exactly. If your data is important then it shouldn't be stored on just the one device.
When you replace a disk or add another one redundancy is reduced or eliminated till the resync completes. If another disk happens to fail during the resync this is a big problem.
You may wish to contact support and enquire about the cost of them looking into the problem you have encountered.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2802 views
  • 0 kudos
  • 3 in conversation
Announcements
