× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ready Nas 102
nasguyindia
Follower
Ready Nas 102
Hello All,
As the ReadyNas 102 device here says  Volume" System Volume root's usage is 97%. This condition should not occur under mormal conditions. Contact technical support. Please help me on this. My number is XXXXXXXXXXX. i have attached log file as well.
Model: RN102|ReadyNAS 100 Series
Message 1 of 2
Guru
Re: Ready Nas 102
If you are running the AntiVirus service, then turn it off immediately.  That won't fix the problem, but it will stop it from getting any worse.
After that, you can contact paid support via my.netgear.com (which is different from the community support you can get here).
Or you can try to fix it yourself using the guide here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-90-RN...
I redacted your phone number, as paid support doesn't monitor this forum.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 420 views
  • 1 kudo
  • 2 in conversation
Announcements
