Orbi WiFi 7 RBE973
Reply
ReadyNAS 214 Volume degraded Replacement disk showing state UNKNOWN
Froglet0
Disk 4 failed. Replaced and started to resynch. Then stopped and said volume degraded. Attempted formatting drive, powering off and on NAS. Somtimes it would re-start a synch and then stop again. Sometimes it would create an additional volume data-0 that had to be deleted.
It is now sitting in the following state:
Volume is degraded, and volume size appears to represent the size with 3 of the 4 disks.
Volumne settings, however, list all 4 disks.
 Disks 1 to 3 are ONLINE, Disk 4 is UNKNOWN
 In the overview Disk 4 shows blue but without the Green indicator. Disk cannot be selected for format.
In the background I can hear the NAS churing the disks.
Is this system still recovering, or is it now unrecoverable?
Can I resolve the volumne degraded state by selectively deleting data, or does it need a factory reset?
Firmware: 6.10.5 Hotfix 1
Log extract:
[21/09/09 23:07:16 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/10 01:27:28 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/10 07:48:32 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST8000VN004-2M2101 Serial:WKD2LAF5 was added to Channel 4 of the head unit.
[21/09/10 07:50:06 WEST] info:volume:LOGMSG_DELETE_VOLUME Volume data-0 was deleted from the system.
[21/09/10 08:34:40 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/10 11:13:13 WEST] notice:disk:LOGMSG_ADD_DISK Disk Model:ST8000VN004-2M2101 Serial:WKD2LAF5 was added to Channel 4 of the head unit.
[21/09/10 11:14:09 WEST] info:volume:LOGMSG_FORMAT_VOLUME_SUCCESS Disk format completed on channel 4.
[21/09/10 11:14:14 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[21/09/10 11:39:16 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/10 12:30:07 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/10 12:36:53 WEST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[21/09/10 12:37:55 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 01:02:49 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 19:40:12 WEST] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[21/09/11 19:47:47 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[21/09/11 20:00:42 WEST] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[21/09/11 20:36:33 WEST] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[21/09/12 01:07:01 WEST] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
disk_info.log
Device: sda
Controller: 0
Channel: 0
Model: ST8000VN004-2M2101
Serial: WKD1A746
Firmware: SC60
Class: SATA
RPM: 7200
Sectors: 15628053168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 6db84bfc
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Command Timeouts: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 48
Start/Stop Count: 32
Power-On Hours: 10039
Power Cycle Count: 32
Load Cycle Count: 54948
Device: sdb
Controller: 0
Channel: 1
Serial: WKD18S54
Firmware: SC60
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Command Timeouts: 0
Temperature: 53
Load Cycle Count: 55105
Device: sdc
Controller: 0
Channel: 2
Serial: WKD1REXC
Firmware: SC60
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Command Timeouts: 0
Temperature: 54
Start/Stop Count: 20
Power-On Hours: 7919
Power Cycle Count: 20
Load Cycle Count: 38644
Device: sdd
Controller: 0
Channel: 3
Serial: WKD2LAF5
Firmware: SC60
Class: SATA
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 10
Guru
Re: ReadyNAS 214 Volume degraded Replacement disk showing state UNKNOWN
Do you have an up-to-date backup of your data?  If not, I think making a backup is the next step.
Message 2 of 10
Froglet0
Hi Stephen,
No, I don't have a backup. The NAS is used to backup various home laptops and I don't have anything with similar capacity to back it up to. If I loose the data, it just means I loose a series of old backups.
Bit annoying as I have a couple of ReadyNAS and each has suffered a disk failure and neither has recovered from it properly. Suggests the RAID implementation is poor.
Further problem is that the warranty replacement Seagate IronWolf disk is a refurbished unit and that appears to now be reporting errors.
Sep 11, 2021 08:17:10 PM
Disk: Detected high command timeouts: [47] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 11, 2021 07:46:47 PM
Disk: Detected high command timeouts: [44] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Sep 10, 2021 12:36:53 PM
Disk: Detected high command timeouts: [43] on disk 4 (Internal) [ST8000VN004-2M2101, WKD2LAF5]. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Message 3 of 10
Guru
The RAID implementation is a standard linux tool called MDADM.  Though I agree that the actual status doesn't seem to be properly reported in the admin web ui.
I'd contact them and tell them that the replacement disk isn't working correctly.  This could well be the actual problem, not a "further problem"
You could try running the disk test from the volume settings wheel.  It might also be useful if you could download the full log zip file, and post mdstat.log (copy/paste it into your reply).
Message 4 of 10
Sandshark
Sensei
Command time-outs can be due to a problem with the NAS, not the drive.  If you were not having any of them with the old drive and now are, it's not likely.  But you could power down, swap that drive with another, and power back up, then see if the errors follow the drive or slot.
Message 5 of 10
Froglet0
@Sandshark Thanks. Unfortunately I don't have a spare drive of that size, however, since I have just left if alone I have had no disk errors. Only had them whilst it was trying to resynch.
Interestingly I have never been able to do a disk test on the volume. I just get 'Failed to initiate disk test. Disk command failed. Code: 14007010001'
Message 6 of 10
Froglet0
@StephenB
Disk test will not run: I just get 'Failed to initiate disk test. Disk command failed. Code: 14007010001'
mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid10 sdd2[3](F) sdc2[2] sdb2[1] sda2[0]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/3] [UUU_]
md127 : active raid5 sdd3[4](F) sda3[0] sdc3[2] sdb3[1]
23427530496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UUU_]
md0 : active raid1 sdd1[5](F) sda1[0] sdc1[4] sdb1[1]
4190208 blocks super 1.2 [4/3] [UUU_]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Fri May 8 20:38:36 2020
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Thu Sep 16 08:24:35 2021
State : clean, degraded
Active Devices : 3
Working Devices : 3
Failed Devices : 1
Spare Devices : 0
Consistency Policy : unknown
Name : 6db84bfc:0 (local to host 6db84bfc)
UUID : 2480f40f:82e9db61:7bc57b1b:41e45fd9
Events : 151370
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
4 8 33 2 active sync /dev/sdc1
- 0 0 3 removed
5 8 49 - faulty /dev/sdd1
/dev/md/data-0:
Version : 1.2
Creation Time : Fri May 8 20:39:04 2020
Raid Level : raid5
Array Size : 23427530496 (22342.23 GiB 23989.79 GB)
Used Dev Size : 7809176832 (7447.41 GiB 7996.60 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Wed Sep 15 21:24:17 2021
Active Devices : 3
Working Devices : 3
Failed Devices : 1
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : 6db84bfc:data-0 (local to host 6db84bfc)
UUID : 0e0fac41:fdb67d37:7cc01f44:177653a3
Events : 158316
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
- 0 0 3 removed
4 8 51 - faulty /dev/sdd3
Message 7 of 10
Guru
What firmware are you running?
@Froglet0 wrote:
mdstat.log
This says that despite the normal-looking status for disk 4 on the volume tab, the NAS believes the disk has failed.
While this could be bay 4 that has failed, it is more likely to be the disk.  One thing you could try is
  1. power down the NAS,
  2. remove disk 4
  3. shift disks 1-3 to slots 2-4 (leaving slot 1 empty).
  4. reboot the NAS
If bay 4 has failed, then then you won't have any access to your data volume.  If disk 4 has failed, then you will.
After the test, I'd power down again and put disks 1-3 in their original position.
If you can test disk 4 with Seatools in a Windows PC, that would likely confirm the diagnosis.  I'd run both the long generic test and (if it passes) the full erase disk test. This will take a while (1-2 days) if they both pass, but I suspect they won't.
Either way, if the first test shows it is the disk, then (assuming the refurbished disk is still under warranty), I'd contact Seagate and tell them to send you another one.
FWIW, I'd also invest in some USB drives and put a backup plan in place for the NAS.
Message 8 of 10
Froglet0
OK, so after a lot of hassle with Seagate support I have eventually got a replacement disk back. Unfortunately I had to pay for the duff drive they sent me to be returned to them. I guess the lesson is don't use Seagate drives in future.
Anyway, plugged the drive in (I got them to send me a new drive rather than a refurbished one). Immediately started to synch. Has now completed synch and all is well again.
Model: RN214|4 BAY Desktop ReadyNAS Storage
Message 9 of 10
Guru
FYI, Western Digital has the same policy.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3063 views
  • 0 kudos
  • 3 in conversation
Announcements
