Orbi WiFi 7 RBE973
Reply
ReadyNAS DUO - need to delete folder contents
PeterD2
Hi all,
Got a fairly urgent and confusing problem with my ancient ReadyNAS Duo.
I have an older Windows machine that created backups to the Duo (\\NAS\Backups\\Office4\). I don't need anything in here any longer, and it's taking up close to 500GB of space. I cannot delete the contents from Windows, nor can I take ownership of the folders as they were created by the ReadyNAS Duo with UNIX permissions and have locked everything and everybody else out.
I can't delete the \\backups share since every other system in my network backs up to that folder, but I can't figure out how to just nuke that entire folder tree. Any help greatly appreciated!
Thanks!
Model: RND2120v1|READYNAS DUO v1 (2TB: 2 X 1TB)|EOL
Message 1 of 4
Accepted Solutions
Guru
Re: ReadyNAS DUO - need to delete folder contents
You can reset the file permissions from the "advanced" tab for the share.
Just check the highlighted menu item, and click "apply" on the lower right.  There will be a pop-up notification when it completes.
It that doesn't let you delete the folder from Windows, then you can alternatively enable http read/write access for the share, and then browse to https://nas-ip-address/backups  You should be able to delete the folder from there.  Note that the share name in https is case sensitive (unlike SMB).
Message 2 of 4
All Replies
Guru
Message 2 of 4
PeterD2
I actually checked both boxes, logged off and back on again from my Windows client and was able to delete the folders in question. Thanks kindly--this was a real bear to solve and I once again have room on my NAS!
Message 3 of 4
Guru
I'm glad I was able to help. Smiley Happy
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1941 views
  • 0 kudos
  • 2 in conversation
Announcements
