- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo v2: lost network connection; both lights at the ethernet port are off
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ReadyNAS Duo v2 device lost connectivity. The device is invisible on the network and both lights at the Ethernet port are off.
Questions: Does that indicate HW problem wirth the device network interface?
Can it be restored by OS reinstall?
If connectivity cannot be restored, how can I get the data from the device, say, to a USB -= attached backup disk? (I did not configure the backup button on the device)
Thank you for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo v2: lost network connection; both lights at the ethernet port are off
What indication do you see on the router/switch side? What do you see on each side when the power is off? Does anything happen if you disconnect and re-connect with power on?
I have a Duo V2 that will not connect properly to any "green" switch. If you are currently on a switch, can you plug it into the router directly or to another switch? How about directly into a computer (just to see what the lights do, we can try talking to it later if it makes a difference)?
In my case, I believe the tranceiver is damaged. I acquired it that way, and I suspect it saw a surge on the ethernet port. The part is unavailable in quantities under 100. I hope your problem is less severe.
