andy-b
Jun 26, 2016Aspirant
ReadyNAS Pro 2 - no access
Hi,
I have suddenly lost access to the data on my ReadyNAS Pro 2. I can log in via the Web admin interface, but all file sharing protocols are off and can not be turned on.
The situation seems similar to that here Shares-lost and I suspect it is due to log msgs causing full OS partition.
But I have also lost ssh access -so I can not see or login to clear.
How can I fix this?
Regards
/Andy
Hostname: velvet
Model: ReadyNAS Pro 2 [X-RAID2]
Serial: 2K21140D000F5
Firmware: RAIDiator 4.2.28
Memory: 1024 MB [DDR3]
IPv4 address: 1: Not Connected
IPv4 address: 2: 192.168.1.8
Volume C: Online, X-RAID2, 2 disks, 13% of 1841 GB used
Well, the original post was suggesting that you use the procedure here: http://onlyblueatwork.wordpress.com/2012/12/04/net
gear-readynas-access-recovery/ followed by mdgm's suggestions after you clean the OS partition
# cd
# sync
# umount /mnt
# mdadm --stop --scando you have a backup?
- MikeFHAspirant
Hi Andy,
Seem's like is a common issue. I even lost acces to the admin GUI and the had to rebuild the OS.
Just for my santy, does you isue look like mine? Link here -> https://community.netgear.com/t5/Using-your-ReadyNAS/cannot-enable-any-readynas-services-in-netgear-readynas/m-p/1105663
Thanks
Mike
- andy-bAspirant
Hi Mike,
Looks like you are using OS 6. I did not upgrade to that. So while the causes may be similar my issue looks different. I can not enable any protocols and the share list has disappeared.
/Andy
- MikeFHAspirant
Thanks.
I am proper stuck ! here...
Looks like i need to back my data up and whipe my NAS and maybe format my disc
Mike
