- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Pro 6 general protection fault: 0000 [#2] SMP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Pro 6 general protection fault: 0000 [#2] SMP
@ninjasniper85_ wrote:
Are you familiar with the linux command line?
hmmm
i will say no
i did some python coding at College
Please guide me
What you'd need to do is look in the /etc/snapper/configs folder. The config files in there are simple numbers (0, 1, 2, etc). One likely refers to /data/ReoLink. You'd need to find that file and delete it.
You'd start by enabling ssh in the web admin ui. is to enable ssh. You could try connecting with WinSCP (using SFTP, with the username=root, and the NAS admin password). That would give you a GUI interface. You could then copy the files to a PC to take a look (I don't recall if WinSCP gives you an option to view them or not).
- Mark as New
- Bookmark
- Subscribe
- Permalink
password not working when i try password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some services are denied if you use the default admin password. So if you are doing that, then change it to something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Admin And Password is change i try the Admin and New Password won't let me in
- Mark as New
- Bookmark
- Subscribe
- Permalink
alright the admin and password account
i change the password 4 times now and the root copy the admin password to the root and still denied
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you enabled ssh, did you check the box next to "Enable Password Authentication"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes
Maybe try disabling it and then enabling it again (making sure that box is checked).
- Mark as New
- Bookmark
- Subscribe
- Permalink
do i have to download the SSH key file?
and yes i try that
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
This is a puzzle, as this works with all my ReadyNAS on both Win10 and Win11.
Have you tried rebooting the NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried rebooting the NAS? Yes
so Root is Admin on the UI?
So if i change the password on the UI for the Admin should be the same as the Root?
So it work in CMD
but not WinSCP
- Mark as New
- Bookmark
- Subscribe
- Permalink
i think it the Port making not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. The ReadyNAS software updates the root password to match the admin password when you change it.
So it work in CMD
but not WinSCP
So SSH now works in CMD?
If so, are you connecting using SFTP with WinSCP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
SFTP
IP: your nas ip
Port: 22
Advanced
Environment > Shell
Shell: Sudo su-
Return Code variable: autodetect
i am in now
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done i have deleted /etc/snapper/configs File 0
🙂 will restart nas and let it be for awhile if no errors or freeze up i will make this as resolved
Thanks StephenB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Uptime Kuma
❌ Your service NAS went down. ❌ Service Name NAS Service URL 192.168.1.2 Time (UTC) 2023-03-19 03:58:28.062 Error PING 192.168.1.2 (192.168.1.2) 56(84) bytes of data. --- 192.168.1.2 ping statistics --- 10 packets transmitted, 0 received, 100% packet loss, time 362ms Today at 2:58 PM
✅ Your service NAS is up! ✅ Service Name NAS Service URL 192.168.1.2 Time (UTC) 2023-03-19 03:59:28.539 Ping 6242 ms Today at 2:59 PM
❌ Your service NAS went down. ❌ Service Name NAS Service URL 192.168.1.2 Time (UTC) 2023-03-19 03:59:58.429 Error PING 192.168.1.2 (192.168.1.2) 56(84) bytes of data. --- 192.168.1.2 ping statistics --- 10 packets transmitted, 0 received, 100% packet loss, time 396ms Today at 2:59 PM
(i didn't have Ethernet in my room few weeks ago i move rooms so now it back)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mar 19 15:01:22 NASV2842021 apache_access[3672]: Admin session started from 192.168.1.212
Mar 19 15:01:30 NASV2842021 dbus[2964]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Mar 19 15:01:30 NASV2842021 dbus[2964]: [system] Successfully activated service 'org.opensuse.Snapper'
Mar 19 15:01:30 NASV2842021 snapperd[30120]: open for '/etc/snapper/configs/0' failed
Mar 19 15:01:30 NASV2842021 snapperd[30120]: THROW: file not found
Mar 19 15:01:30 NASV2842021 snapperd[30120]: config '0' not found
Mar 19 15:01:31 NASV2842021 msmtpq[30191]: mail [ 1 ] [ 2023-03-14-22.20.15 ] from queue ; couldn't be sent - host not connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am wondering about the hardware checksum errors. Did you move the NAS? Does switching to the other ethernet connection resolve them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, so it doesn't like no 0 configuration.
/etc/sysconfig/snapper contains a list of configurations. From my experiments, deleing a share doesn't re-arrange the snapper configs, it removes one. So if you just remove 0 from the list, it should work.
As with any messing with configuration files, it is advisable to back the file up before editing, just in case you make a mistake that makes things worse.
Now, something also schedules these things, and the schedule isn't in the configuration files, so this may not be the last layer of the onion if the removed configuration was enabled with a schedule.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sandshark wrote:/etc/sysconfig/snapper contains a list of configurations. From my experiments, deleing a share doesn't re-arrange the snapper configs, it removes one. So if you just remove 0 from the list, it should work.
my bad, I forgot to check whether snapper had a list of configs or not.
@ninjasniper85_ - if you edit this file using WinSCP, you will want to open it with Notepad++ (not notepad). Notepad++ is freeware. Go into edit->EOL conversion and make sure that is set to Unix (LF) before saving the file. Notepad++ handles this a bit differently from what I expect - the option you are currently using for the EOL conversion is grayed out.
But I am more concerned about the other errors. Not sure what is going on, but I am worried it might be hardware related. The ethernet checksum errors are unusual. And the recursive general protection fault is still happening.
You could try running a memory test I guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
## Path: System/Snapper
## Type: string
## Default: ""
# List of snapper configurations.
SNAPPER_CONFIGS="2"
- Mark as New
- Bookmark
- Subscribe
- Permalink
## Type: string
## Default: ""
SNAPPER_CONFIGS="2"
Interesting. Is there a 2 in /etc/snapper/configs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No there was 0 2 i remove the 0 so i think it will be ok now just have to wait 3 days + now to see if the issues happen again
Sorry for not explain was very busy this morning
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Though I am thinking that the snapperd problem is a bit of a distraction, and that we haven't sorted out what the real protection fault cause is.
Although painful,
- backing up the data
- doing a factory default
- reconfiguring the NAS
- and restoring the data from the backup
might be the best step.
If the problem is due to a software issue that crept in, then the default would resolve it. But if the NAS hardware is failing, it will continue.
