× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Pro Pioneer - Cannot allocate memory failure
greenleaf-noho
I have a ReadyNAS Pro Pioneer (RNDP600E-100NAS) that is running on firmware version RAIDiator 4.2.28 with memory of 1024 MB [4-5-5-15 DDR2] with 2 - 1.5TB Seagate Barracuda SATA 7200 RPM, 32MB (ST31500341AS) hard disk drives.
Current usage of the 2 disks, X-RAID2 configuration, is about 53%
I have just started to utilize the backup feature (Remote: Windows/NAS (Timestamp) on the Front Panel to run a backup of 'volume c' to a 2TB HDD that is mounted in my Windows 7 machine as drive 'D'.
I get a 'cannot allocate memory' failure.
Any help would be appreciated
Message 1 of 17
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS Pro Pioneer - Cannot allocate memory failure
Message 12 of 17
All Replies
mdgm-ntgr
Where do you see this error message?
Which services or add-ons are you running?
Can you send me your logs (see the Sending Logs link in my sig)?
Message 2 of 17
greenleaf-noho
The error message is reported to me in the 'Backup Job Log'
Add-ons:  ReadyNAS Photos II (never used)
Message 3 of 17
greenleaf-noho
I emailed logs on 12-28 as requested, what is the next step?
Message 4 of 17
mdgm-ntgr
The email never arrived. Can you check you sent it to the correct address?
Perhaps also try sending it from a different email address.
Message 5 of 17
greenleaf-noho
Thanks for your response, logs resent just now.
Happy New Year!
Message 6 of 17
mdgm-ntgr
Odd. I still can't see them. Perhaps try a different email address or if you've already done that PM me a link to the zip file.
Message 7 of 17
greenleaf-noho
I just resent the files again, this time extracted from the zipped file.  I am not sure what 'PM' stands for.
Message 8 of 17
Guru
PM-> private message.
You send them using the "messages" link at the top right of the forum page.
Message 9 of 17
greenleaf-noho
Ok, thanks for the clarification.  We thought that's what it meant but we didn't see the link on top.  So I checked the messaging option, I am not sure how to attach 61 log files, sorry for the confusion on my part.
Message 10 of 17
Guru
You'd need to save them on a server somewhere (put a zip in google drive for instance) and put a link in the PM.
Message 11 of 17
mdgm-ntgr
Message 12 of 17
greenleaf-noho
Update:  These changes appeared to have helped significantly.  The backup ran for nearly 6 hours, however there was an errror message again.  Zipped log file will be PM'd.
When I compare the file quantity on the source to the backup it was 7 files short (~4MB worth) out of the 101,147 total files.
I think I am close to having a successful backup, but I can't locate the error message to see if there was/is a problem.
Thanks for all of the help.
Message 13 of 17
mdgm-ntgr
All the backup job logs I can see are from late December.
Which backup job number are you using?
Message 14 of 17
greenleaf-noho
Number 5 at that time.
I forgot to check my email for the error list, this is what I got:
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Philip Hamel\'s side of the family (Hamel, Champagne, Cloutier, Beauchamp, Lacombe)/Scanned Images/1880FE~3.BMP': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~2.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/1928-1~1.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/1987-0~2.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~1.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~3.JPG': File exists
Which oddly enough adds up to 6 files, 1 short of the 7 differential.
I have since removed this files and I am running another complete backup to test, previous changes.  Backup started at 4:12 PM EST, so should be finished between 10 and 11.  More to come
Message 15 of 17
greenleaf-noho
Previous backup attempt also had errors because the offending files when copied and then deleted were transferred to the recycle bin.  I removed them from the recycle bin and reran backup this morning with complete success after 6 hours.
One other backup related question... is it okay to use (read/write) the fileserver while the backup is running?
Message 16 of 17
Guru
I've had backups fail when files are deleted on the source while the backup is running (though whether that happens might depend on the specific backup protocol being used).  So updating files is best avoided.
There are no issues if the files are simply being read.
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 5553 views
  • 0 kudos
  • 3 in conversation
Announcements
