× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas 104 500 error
fayazkhan
Re: ReadyNas 104 500 error
rebooted after clearing space same error
Message 26 of 54
fayazkhan
Hi,
After disk cleaned we have 1.32 GB used space , device booted into normal mode still the same error
putty does not work , what will be the next step please.
Thanks
Message 27 of 54
Guru
I suggest trying an OS reinstall from the boot menu next.  Note that will reset the admin password back to password.
If you can log into the web ui, then immediately disable the antivirus software on system->settings->services
Message 28 of 54
fayazkhan
Hi,
We dont want to lose data as no backup i will re install os from boot menu if it does not wipe data please advise
Thanks
Message 29 of 54
Sandshark
Sensei
As long as you do an OS re-install, not accidently do a factory default, then your data will be fine.
Message 30 of 54
fayazkhan
Hi,
what are the steps to re install OS
Thanks
Message 31 of 54
fayazkhan
I have re installed OS and logged in but some of the data missing
Message 32 of 54
Guru
@fayazkhan wrote:
I have re installed OS and in but some of the data missing
Entire Shares? Or files/subfolders within shares?
Did you disable the antivirus service?
Message 33 of 54
fayazkhan
Hi,
I disabled anti virus , not entire but some of the folder are empty , i only have homefolder with some the data 1.3 TB data still there
Message 34 of 54
fayazkhan
i am unbale to join to domain as well
Message 35 of 54
fayazkhan
I am downloading data it is taking long time 3 GB in 2 hour what is the best and quick way to backup data.
Thanks
Message 36 of 54
fayazkhan
all data setting in there and i cannot share it
there were share before OS re install
Message 37 of 54
Guru
Can you see these missing files using the admin web ui?
Message 38 of 54
fayazkhan
i am seeing some folder empty only one folder showing data that is not that much what is taking that much space 1.3 TB , i checked folder with highlighted folder they all empy
i can see folder structre but all folders empty look like data is hidden and it says uage
there is data not sure how i will see that data
Thanks
Message 39 of 54
Guru
Is all the missing data in the home folders?
Or is some in public shares? (Grateley appears to be a public share, there might be more below the home folders).
You can see the home folders from Windows if you connect to the NAS using admin credentials.
For instance, if you enter this into CMD
net use * /d /y
net use z: \\GHSReadyNAS\data /u admin admin-password
Substituting the real NAS admin password for admin-password.
This mounts the full data volume as drive letter Z.  Note this won't work if you still have the admin password set to password.
Message 40 of 54
fayazkhan
Hi,
Folder Grateley i created after os re install that does not have any data Home folder have all the data but not visible i reset password tomorrow and will map drive may be will see data
Thanks
Message 41 of 54
Guru
Normally there is one folder per account in home.  Access either requires using the credentials for that account, or using admin credentials.
Your home folder looks like you might be sharing an account with multiple users - not sure if that is how you set it up, or if that is a side-effect of damage to config files that was done when the OS partition filled.
I am thinking that the priority now is to get all the data copied off.  Then we can upgrade the firmware (which requires two steps in your case).
There is a repair script we could try to fix the shares - not sure if it will work, and we definitely should back up the files before we attempt it.
Another option would be to do a factory default, reconfigure the NAS from scratch and restore the files from backup.
Message 42 of 54
fayazkhan
Hi,
How i will see data and can take backup then can proceed with further actions
Thanks
Message 43 of 54
fayazkhan
i have reset admin but still not mapping share
net use * /d /y
Message 44 of 54
Guru
What error are you getting?
Did you replace admin-password with the real admin password?
Also try replacing GHSReadyNAS with the NAS IP address.
Message 45 of 54
fayazkhan
getting below when using IP
The network path was not found.
Message 46 of 54
Guru
Maybe reboot the PC and try again.
Message 47 of 54
fayazkhan
Same issue after reboot and i cannot join to domain as well
Message 48 of 54
fayazkhan
not finding a way to access this 1.3 Tb data and we don't have backup, even i created new share at the root copy over all those folder from home drive still unbale to access from windows PC and unbale to join as well
Message 49 of 54
Guru
Try enabling ssh in system->settings->services.  Choose the option to "Enable password authentication".
Then connect to the NAS with ssh, logging in as root and using the NAS admin password.
See if you can find what you are looking for in /data.
Obviously something to fix after you get the data off.
Message 50 of 54
Top Contributors
Discussion stats
  • 53 replies
  • 4805 views
  • 0 kudos
  • 5 in conversation
Announcements
