× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Ultra 4 plus stuck on booting (though boot menu is working)
Guru
Re: ReadyNas Ultra 4 plus stuck on booting (though boot menu is working)
@waled wrote:
anyone explain what is happening, please?
I suspect that the data was lost because of file system corruption, combined with a file system check/repair on on of the boot attempts.
That's just a partial answer, since the cause of the (theorized) file system corruption isn't completely clear.  If the failing disk somehow had bad data (that could still be read without an error), then that could do it.  If somewhere along the line you had to pull the plug to power down the NAS, then that could create corruption too.
If you accidentally pulled/reinserted a different disk (say disk 1), then that could explain it also.
Message 26 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 4686 views
  • 7 kudos
  • 3 in conversation
Announcements
