× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas 1100 Active direcrory option is not found
szucsmiki
Hello
My company uses a Redynas 1100 for long ime, it was joined the domain. It had some problem, so I did a factory reset, now it is up and running, but cannot find the option to join the domain. Where this option should be, at the security menu there is no option to join the AD as before. Only local users and groups can be managed. The firmvare is: RAIDiator 4.1.14.
Can anyone help me? How can I join the device to the domain?
Thanks: Miki
Model: ReadyNAS-1100|ReadyNAS 1100
Message 1 of 9
Retired_Member
Not applicable
Re: Readynas 1100 Active direcrory option is not found
Hi,
User manual page 27: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf?cid=gwmng
Select a Security Mode
This procedure applies only to the ReadyNAS NV+ and 1100.
To select a security mode:
1. From the FrontView main menu, select Security > Security Mode.
2. Select either Share, User, or Domain.
Message 2 of 9
szucsmiki
Thanks for quick answare...
I have read the article you mentioned, but there is no Security Mode option under Security menu.
I have searched for this option in the menu structure but couldn't find...
Any suggestion?
Thanks:Miki
Message 3 of 9
Guru
Possibly the firmware is confused on the NAS model (treating your system like a Duo).  If so, you will need Netgear support to fix it.
Message 4 of 9
szucsmiki
It is a Readynas1100 system and support has ended...
Is it possible to downgrade the firmare?
Message 5 of 9
Guru
You can still get per-incident support if you are the original purchaser - even if the warranty has expired.
I think this happened when you reset.  I don't think downgrading the firmware will fix it, but you can try it.
What model are you seeing on the home page?  Model information is stored in an EEPROM in the NAS, and it is possible that information has gotten a bit messed up.
Message 6 of 9
szucsmiki
This is what is on the homescreen:
After the factory reset the firmware stayed as it was 4.1.14.
I'll try downgrading to 4.1.13... Will let you know the result...
Thanks:Miki
Message 7 of 9
szucsmiki
Hello
Downgade to 4.1.13 did not helped, the oldest firmware I found is 4.1.9 but downgarding to that was useless too.
Any idea how to get back the option to join the device to domain?
Thanks:Miki
Message 8 of 9
mdgm-ntgr
NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4181 views
  • 0 kudos
  • 4 in conversation
Announcements
