× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Renaming USB Storage on RN314
kbrownremed
Follower
I currently have a ReadyNAS 314 device running OS 6.6.0.
Currently, we are using this device to copy backups to an external USB drive, and then taking them off-site.  We have 2 drives that we are rotating, but it seems that the ReadyNAS has labeled them USB_HDD_1 and USB_HDD_2 and I cannot change them.  I have searched everywhere in the SSH access to see if there is somewhere where I can manually change them, but I cannot find anything.
I understand that this is a feature that has been requested, but I need to get both of these drives to appear as USB_HDD_1 ASAP so our backups are not complicated.  Currently it takes a lot of manual intervention to re-sync the backups once the drives have been swapped.
Is there any way that I can do this using SSH or do I have to open a support ticket?
Is there an older version of the firmware that I can roll back to so that I can rename the drives?
Model: RN31400|ReadyNAS 300 Series 4- Bay
Message 1 of 3
FramerV
NETGEAR Employee Retired
Re: Renaming USB Storage on RN314
Good day kbrownremed.
Welcome to the community.
I think there is nothing we can do regarding the way the ReadyNAS identifies the plugged USB devices.
As far as I know, you can edit your back-up job in way that instead of the name of the device name; the positioning of the USB device is designated as the destination (example: USB Back Top, USB Front). Doing this would make the back-up go to the same USB port regardless of its name.
As for downgrading, NETGEAR clearly stated not to downgrade. Below is a link for the firmware release:
http://kb.netgear.com/app/answers/detail/a_id/31221/~/readynas-os-6-software-version-6.6.0?cid=wmt_n...
Message 2 of 3
FramerV
Hi kbrownremed,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4187 views
  • 0 kudos
  • 2 in conversation
Announcements
