× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Reset Password - I give up!
jtriplej
Follower
I have a ReadyNAS Duo V 1. I have had it for about a year and a half and have never had to do anything with the settings after initial setup. Now I do want to change some settings and for the life of me I do not know the username and password I set up.
I have read all the FAQs. I have done the OS re- install steps. I'm using Raidar 4.1.3 and it does find the NAS on the network but when I try to login I get denied. I have tried to log in from XP, Vista, and 7 machines. I've tried 3 different browsers on each.
On all of the above I have tried the following combinations and a few more that I can't even remember:
admin admin
admin password
admin netgear1
admin password1
password password
I tried the password recovery and it gave me a message that it was sending me an email that has been 5 hours ago which is when I first started working on this. Can someone please help me?
Message 1 of 3
PapaBear1
Apprentice
Re: Reset Password - I give up!
Password recovery only works if you had set it up. The default for your Duo (v1) would be admin, netgear1 which you apparently have already tried. Since that did not work, you must have changed the password. You cannot change the user ID from the default admin.
What will work is a firmware reinstall, NOT a factory default (which wipes the data) so be careful.
Here is the process:
Message 2 of 3
mdgm-ntgr
NETGEAR Employee Retired
If an OS/firmware re-install doesn't fix the problem it's likely some configuration files have been corrupted and you should contact tech support (http://www.ReadyNAS.com/support) for assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 923 views
  • 0 kudos
  • 3 in conversation
Announcements
