Jenac
Sep 15, 2013Tutor
Router starts rebooting when I enable teaming on RN516
Problem for Adaptive Load Balancing (ALB) on RN516.
Setup. Router ASUS RT-AC66N running latest FW, acting as DHCP, most permanent devices have a fixed IP, running normal 1500, not jumbo package.
Connected to this one is:
1) Netgear GS108Tv2 (for Smart-TV, apple-TV, PS3 etc)
2) Netgear GS116E (for PC:s, NAS, printers, master for power-lines to rooms without ETH etc).
ASUS RT-AC66N is a great router that ran perfect without reboots for 3-6 months. As soon as I enabled the teaming on my ReadyNas 516 the router started to reboot and have problems so I actually RMAed it :oops: .
When the brand new router behaved the same way I started to think about changes I made recently and removed teaming. Problems stopped.
Anyone seen the same behavior, or even better, have a solution?
- vandermerweMasterDoes the NAS have a fixed IP address?
You could try disabling GRO in the router - apparently in LAN/ switch control part of router admin, although I believe asus may have removed/ disabled it because of the problems it caused. Check anyway.
Is the anything in the router logs that might give you a clue?
Have you asked the router manufacturer's support, this sounds like a router problem, not a readynas problem? - StephenBGuru - Experienced UserIf there is a setting for GRO you should certainly start by disabling it.
Why not use standard IEEE standard LACP/LAG? - your switch supports it. That would almost certainly work around the problem since it is strictly layer-2, and would give you all the teaming benefits of ALB. I believe the GS116E has a web interface to configure this (my GS724T does), there is also a configuration utility you can download from netgear.com.
If for some reason you are determined to use ALB, if you are using dhcp (normally or with address reservation) for the NAS you might try switching to a static address. ALB messes with ARP, and that conceivably could be confusing the asus dhcp (esp. if you are using address reservation). - JenacTutorThanks for the ideas guys!
GS108Tv2 is better for teaming than GS116E (no support for team that requires config on the switch side on that one...).
No logs on the router that helps either. I'll check if more detailed logging can be turned on.
Did have time in the last two weeks to play around. Without teaming everything runs fine, but it would be nice to be able to turn on. - StephenBGuru - Experienced UserYou're right - I saw LAG supported in the configuration utility, and assumed that all the smartswitches supported it. However many of them don't (including the GS116E).
If you need to stick with the GS116E, then perhaps transmit load balancing is the best you can do. I suspect that will not create any issues with the router. If you can upgrade to a GS116T-200 switch, then you'd get LAG/LACP support.
Though teaming generally doesn't make that much difference in a home environment. Each session remains limited to 1 gbit, so it only helps when multiple users are accessing the NAS simultaneously for large sequential file transfers. If the files are small (or the users are doing random I/O), then you are usually limited by the disk seek performance, not the network.
