× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Rsync broken since 6.7.1 & 6.7.3
davidr1
Luminary
The 3100 only received Notification to upgrade to 6.7.1.
Since then backing up using rsync sometimes fails within a minute.
The Pro received a notification to upgrade to 6.7.3 - not 6.7.1.
Since then all rsync backups fail within a minute.
I can not backup /data locally to the USB drives because I can not provide an exclude list this way.
Any help please with rsync since 6.7.1 / 6.7.3 ?
Model: ReadyNAS-3100|ReadyNAS-3100,ReadyNAS RNDP2110|ReadyNAS Pro 2
Message 1 of 54
davidr1
Luminary
Re: Rsync broken since 6.7.1 & 6.7.3
I should clarify this ...
It actually claims 'complete' - but only the folders exist on the backaup - not the contents of those folders.
e.g.
Backing up the /data directory, the backup /data/databse exists but /database is empty on the backup, as are all other folders backed up.
Message 2 of 54
davidr1
Luminary
Upgrading to 6.7.4 did not change anything.
Whether using rsync and backing up NAS to NAS or NAS to USB, only the folder structure is 'backed up' - no folder contents.
Using rsync to backup a share also does not back anything up.
This has been working properly until the recent FW updates.
Please - can anybody help?
Message 3 of 54
TeknoJnky
Hero
rsync is working for me on all 4 my nas running 674
Message 4 of 54
TeknoJnky
Hero
are you getting any errors in your logs? check your backup setting to see if you have 'on completion send full backup logs'.
If you are getting out of space or write errors, you might try; system > volumes > click gear > balance
Message 5 of 54
davidr1
Luminary
Thanks for responding.
The settings haven't been changed - they were working for months / years OK
Log reports job completed successfully.
Email shows only data structure:
Successfully completed backup job Pro Daily Data.
-------- Backup Job Information --------
Backup Job Name: Pro Daily Data
Backup Job Type: Full
Protocol: rsync
Backup Source: [volume:data]/
Backup Destination: [remote:rsync]/192.168.1.8::USB_HDD_1
Backup Start Time: Tue May 30 2017  8:15:19
Backup Finish Time: Tue May 30 2017  8:15:19
Backup Status: Success
-------- Backup Job Log --------
sending incremental file list
data/
data/copies_of_usb/
data/database/
data/documents/
data/filing_cabinet/
data/financial/
data/howtos/
data/software/
sent 441 bytes  received 56 bytes  994.00 bytes/sec
total size is 0  speedup is 0.00
and looking at the backup only shows empty folders.
Each day is a full backup onto an empty drive.
Message 6 of 54
mdgm-ntgr
NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
The last firmware we updated rsync was 6.4.1, I think.
Message 7 of 54
mdgm-ntgr
Support has let me know there's been another report of this issue and that they've reproduced it.
Message 8 of 54
Yes this is the exact same issue that I'm having
what did support say can we expect a fix anytime soon
Message 9 of 54
davidr1
Luminary
Thanks mdgm,
I thought I was going out of my mind 🙂
It was working fine after 6.4.1. - broke after the recent updates.
Logs sent.
Did they indicate a 'fix' time given backing up is critical?
Message 10 of 54
nsne
Virtuoso
I saw this too. I back up a 314 to an Ultra 4. After 6.7.1, rsync stopped working on a backup job that had always worked just fine. Exact same log types.
I'm waiting for my 314 (a new one, after this error borked my old one) to finish a data scrub before trying the backup job again.
Model: RN31400|ReadyNAS 300 Series 4-Bay
Message 11 of 54
nsne
Virtuoso
Still seeing this in 6.7.4 on both boxes (source 314, destination Ultra 4). Backup instantly "succeeds" with no data copied.
Message 12 of 54
davidr1
Luminary
Ignore this post - duplicated. Apologies.
Message 13 of 54
Any updates on when this may be fixed or has anyone found a workaround
Message 14 of 54
bedlam1
Prodigy
I suffered Rsync backup problems and decided to manually do a OS Install back to OS 6.7.1, Rsync is running normally again for me now
Message 15 of 54
Sharpy
Do you mean a factory reset (format all data gone) or a OS reinstall from the boot menu
Message 16 of 54
bedlam1
Prodigy
Neither
First download OS 6.7.1 then using The Admin page go to System/Settings and use Manual Install Firmware
Message 17 of 54
Is that a recommended procedure
Message 18 of 54
bedlam1
Prodigy
I have no idea (although Netgear warn not to go back) but it worked flawlessly for me and I urgently needed a solution, particularly as 6.7.2 and then 6.7.4 broke Rsync.
Your NAS will of course advise there is an update to 6.7.4, which I am going to ignore and when 6.7.5 emerges I will hold of that too for a few weeks
Message 19 of 54
Guru
No.
https://community.netgear.com/t5/ReadyNAS-Firmware-Release-Notes/ReadyNAS-OS-6-7-4-now-available/m-p...:
Devices updated with 6.7.4 firmware should not be downgraded to earlier firmware versions
Though it seems to have worked out for @bedlam1.
Message 20 of 54
jak0lantash
Mentor
Afaik, this is untested, so random issues may be encountered.
Message 21 of 54
Sharpy
Thanks think a will leave that then and wait for an official firmware update
It's taking a while for the fix tho
Message 22 of 54
mdgm-ntgr
Support reproduced the issue only about a week ago.
The issue has to be verified again, the root cause identified, a fix prepared and QA tested.
Firmware updates tend to have multiple changes. So it can take some time before we have a sufficient quantity of fixes and other improvements to justify a firmware release.
Message 23 of 54
I would appreciate that answer if this wasent about backups. Because it's about backups one of the most important parts of owning computer systems if you have a fix you should push the update ASAP not when there's a bundle of fixes
anything pertaining to backups should be a problem of the maximum urgency and shouldn't be broken in the first place
any other bug is acceptable apart from things that impede data access or security of said data
in my opinion
thanks for the update tho mdgm
Message 24 of 54
davidr1
Luminary
I must agree with this.
Please could we have an rsync specific fix rather than a bundle of other changes (unless, of course, they are required for rsync)?
Could support instruct a non-destructive way of downgradinfg to 6.7.1 or the one before?
David
Message 25 of 54
Top Contributors
Discussion stats
  • 53 replies
  • 7363 views
  • 4 kudos
  • 12 in conversation
Announcements
