Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rsync just hangs..
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
03:30 AM
2013-09-19
03:30 AM
Rsync just hangs..
So I have three shares on a ReadyNAS 3200 that I'd like to sync with a ReadyNAS Pro 4 which is used as an in-house backup, before the data is eventually backed up onto external HDDs and removed off-site. The share's contain a fairly sizeable amount of data 100s of GB.
No matter what I do, I cannot get the 3200 to backup the three shares to the Pro 4. Ideally I'd like to get the first data backed up using a standard NFS backup then switch to a Rsync incremental backup that will run every few hours each day.
When attempting to backup using NFS shares from the Pro "pulling" data from the 3200, it never gets started, just hangs. If I "push" the data from the 3200 to the Pro, it starts and very slowly copies some files over, then the 3200 Frontview stops responding and the backup simply halts.
If I try to do the first backup using Rsync, no matter which way around I try it, they always both get stuck at "receiving incremental file list" and while neither locks-up or fails to respond, nothing actually happens (I've left it for 7 days+ once and still nothing).
Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
03:51 AM
2013-09-19
03:51 AM
Re: Rsync just hangs..
What version of RAIDiator is on the units?
Message 2 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
03:59 AM
2013-09-19
03:59 AM
Oh I suppose I should give some more information about the devices / software:
Model: ReadyNAS 3200 v1 [X-RAID2]
Firmware: RAIDiator 4.2.22
Memory: 4096 MB [DDR2]
IPv4 address: 1+2: 192.168.0.157
Model: ReadyNAS Pro 4 [X-RAID2]
Firmware: RAIDiator 4.2.24
Memory: 1024 MB [DDR2]
IPv4 address: 1+2: 192.168.0.158
Both devices have their network interfaces in teaming mode (IEE 802.3ad LACP - Layer 2).
Message 3 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:09 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:15 AM
2013-09-19
04:15 AM
Not as yet, I thought I'd try here first...
Message 5 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:25 AM
2013-09-19
04:25 AM
Is either NAS under heavy load? Have you checked to see if the 4GB OS partition is very full one other unit?
Message 6 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:29 AM
2013-09-19
04:29 AM
The ReadyNAS 3200 is probably under a reasonable workload as it's the main VMware NFS host..
Is there an easy way to see what load it's actually under?
Message 7 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:33 AM
2013-09-19
04:33 AM
Well if you are comfortable with the support implications of enabling SSH you could run top
Message 8 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:37 AM
2013-09-19
04:37 AM
Two questions; how likely are support to refuse to help if I've enabled SSH access? Do I need to reboot the NAS to enable SSH? (if so, no can do until out of business hours)
Message 9 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:39 AM
2013-09-19
04:39 AM
I would suggest you download your logs (Status > Logs > Download all logs), open an online case and attach your logs to your case.
Message 10 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:45 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:47 AM
2013-09-19
04:47 AM
That looks like a pretty light load.
What's the output of
# df -h
Message 12 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
04:52 AM
2013-09-19
04:52 AM
Yeah, I mean while it's the main NFS datastore for the VMs, there a) aren't that many VMs and b) even less that actually do very much work... (There's 1 with SQL server installed and an accountancy package server, probably make up 99% of the usage)
Message 13 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
05:12 AM
2013-09-19
05:12 AM
I think you should contact support for assistance.
Message 14 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
06:44 AM
2013-09-19
06:44 AM
I've just sent a request and linked this thread...
Is it normal for that amount of memory to be used? I mean, there's barely any available and none of the processes seem to be using any...?
Message 15 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-19
06:52 AM
2013-09-19
06:52 AM
It's normal.
If you look at the logs or do
You will see that a lot of RAM is used for caching to improve performance. The memory will be freed up if needed for other tasks.
# cat /proc/meminfo
Message 16 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-10-25
05:05 PM
2013-10-25
05:05 PM
Some questions,
1. What are you rsyncing source and destination?
2. Are you able to rsync to the 3200 as the destination vice versa?
3. Are you initiating this job from the GUI or command line?
Message 17 of 18
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-01-03
03:26 PM
2020-01-03
03:26 PM
Holger Ohmacht aka h8ohmh / 8ohmh:
The problem lies in the filesystem buffer / usage of the interworking of harddisk/hw so far as I could investigate.
Temporal solution for local drives (eg. USB3<->HD) : A script which is polling the changing disk space. If no changing free disk space then rsync is stalled and have to be restarted
cmd="rsync -aW --progress --stats --preallocate --super <here your source dir> <here your dest dir>" eval "$cmd" & rm ./ndf.txt rm ./odf.txt while [[ 0 == 0 ]]; do df > ./ndf.txt cmp ./odf.txt ./ndf.txt res="$?" echo "$res" if [[ $res == 0 ]]; then echo "#################################################" ls -al "./ndf.txt" ls -al "./odf.txt" killall rsync eval "$cmd" & else cp ./ndf.txt ./odf.txt fi sleep 60 done
Change `<source dir>` etc to your paths!
In my case it is always stalling after some few 100's files by usage of rsync's --preallocate option files (normally because of better disk performance and rescueing continuous blocks), so as long as the disk and filesystem drivers not reworked there just this solution
Model: ReadyNAS-OS6|, RN21400|ReadyNAS 214 Series 4- Bay (Diskless), RN214D41|ReadyNAS 214 Series 4- Bay (4x 1TB Desktop)
Message 18 of 18
