× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Slow backup to USB
PelleS
Guide
Slow backup to USB
Hi,
The backing up of my RN214 to USB3 disk on back port is ridiculously slow. Last time the backup job took almost 16 days and this can't be normal!!! I backup around 3,23 TB data to a WD 5 TB disk. Have tried to format the USB disk prior to starting the backup, but it makes no difference. Running OS 6.10.9 on my RN214.
Does anyone have any clue on how to solve the problem?
Message 1 of 5
Sandshark
Sensei
Re: Slow backup to USB
That's definitely excessive.  Can you give some specifics?
USB drive is formatted NTFS or EXT?
USB drive is self-powered or USB powered?
Backing up using what protocol?
Message 2 of 5
Guru
It would also be useful to know if the drive is SMR or not.
Message 3 of 5
PelleS
Guide
Hi,
The USB drive is formatted EXT and it is USB powered (the USB port in the back of the RN214). As for the backup protocol I’m uncertain, I’ve used the default values when setting up the backup job.
Message 4 of 5
PelleS
Guide
Hi,
The USB drive is formatted EXT and it is USB powered (the USB port in the back of the RN214). As for the backup protocol I’m uncertain, I’ve used the default values when setting up the backup job, and don’t know if the drive is SMR (sorry for my lack of knowledge…).
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1170 views
  • 0 kudos
  • 3 in conversation
Announcements
