Donaldini
Jan 05, 2012Aspirant
Slow copying speeds
I'm getting very slow writing speeds when writing to my new ReadyNAS NV+
1. RAIDiator version: 4.1.8
2. Performance tab settings:
3. Network switch model (and firmware version):
CBN SVG6540E with router Apple Time Capsule (firmware 7.6)
4. NIC on MacBook Pro:
Broadcom 57765-B0
5. Number of disks and disk models:
2 Disks: WD15EARS-00Z5B1 1,5TB (main disk) & Seagate Baracuda Green ST2000DL003 2TB
6. The read/write MB/sec numbers from drag & drop test:
MacBook <-- Time Capsule --> ReadyNAS via Ethernet:
AFP: average 14,5MB/s
CIFS: average 13,8 MB/s
FTP: average 1,5MB/s
Writing a 4,5GB file to the NAS
Broadcom 57765-B0
- DonaldiniAspirantI've just tried hooking up a disk using USB to the ports in the back of the NV+ and used ssh to copy a file to the NV+
rsync --progress -ah /USB/file.iso /c/Share/file.iso
The file is a 700MB ISO and had an average write speed of 2,40MB/s.
Also a pretty slow write speed in my opinion. - StephenBGuru - Experienced UserWould be interesting to know what number you get if you just copy it with cp instead of rsync. What format is the USB drive?
- DonaldiniAspirantBecause I have to time it I can't really make it specific, but I guess it's around 5 to 8MB/s, still pretty low no?
USB Drive is NTFS formatted. - StephenBGuru - Experienced UserI agree it is pretty slow. 4.1.9 beta is supposed to be faster.
ext3 is the fastest format, though it is harder to read on Window's PCs. Not sure about Mac though. - mdgm-ntgrNETGEAR Employee RetiredCongrats on your new NV+ v1 purchase!
I can see that your WD disk is not on the Hard Disk HCL. It could well be the problem and NetGear would deny support to help you troubleshoot performance unless this disk is replaced.
Can you download your logs and check partition.log? If your disks are not 4k sector partition aligned that could be a problem. See http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
EXT3 drivers are need for Windows and Mac to read EXT3 formatted disks. Neither supports them natively. - DonaldiniAspirantIf I read it right, the discs should be 4k aligned, no?
Also I guess sda is my connected USB disk (because it was gone in the logs when i removed it).Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 1500.2 GB, 1500291424256 bytes
255 heads, 63 sectors/track, 182400 cylinders, total 2930256688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 2930240335 1462816152 5 Extended
/dev/hdc5 4608040 2930240335 1462816148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
224 heads, 19 sectors/track, 918004 cylinders, total 3907029168 sectors
Disk identifier: 0xe30c5291
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS
/dev/sda2 206848 1965320191 982556672 7 HPFS/NTFS
/dev/sda3 1965320192 3907024895 970852352 7 HPFS/NTFS - DonaldiniAspirantAnyone?
- There are known issues with the speed of 4.1.8. Try 4.1.9 T2 beta if you feel comfortable running it or even downgrade to 4.1.7.
