- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Stuck booting. ReadyNAS NVX
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone.
I was given a ReadyNAS NVX from my neighbor that is stuck at “Booting...”. He gave it to me knowing that I have a ReadyNAS box.
I have been reading a lot on here and on Google about what to do. I created a USB recovery stick and had no luck. Everything in the Boot Menu hangs, except for the memory test.
Here is my worry. About a month ago I told him about the new 6.0 software that I was running on my ReadyNAS, but told him I don’t think it would work on his since his was 32 bit only. I am willing to bet that he tried to do the upgrade.
Im borrowing a USB / Serial cable to connect to the NVX tonight to see what is happening, but any heads up or thoughts would be great. I am afraid that he might have bricked it trying to get the 6 software on it...
Thanks in advance....
—tom
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
After 6 USB sticks, and constant messing around with Disk Part, USB recovery 6 (which I kow wont work with my 32 bit box), USB recovery 4, Formating the USB in OSX and Windows...
I dont know what happen, but I booted off the USB!!
It did its thing, and the box shut down. On reboot I got an error, but booted to factory reset... Bingo Im back in business!
Turning on quotas.
Initializing random number generator... done.
Starting frontview boot scripts: frontview_rc.
Starting portmap...done.
Starting system log daemon: syslogd.
Starting deferred execution scheduler: atd.
Starting kernel log daemon: klogd.
Starting periodic command scheduler: cron.
Starting Samba daemons: smbd.
No ntpd found running; none killed.
RAIDiator 4.2.31 [192.168.1.241]
nas-AA-15-30 login:
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Stuck booting. ReadyNAS NVX
How does it behave if you power it up with no disks installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, Didn’t even think of that. Just tried it and its the same. “Booting...”
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe check the seating on the memory cards next.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No memory problems reporting with the boot menu test. I was able to connect to the serial port.
Below is the output from the cable.
Having a problem now with the USB recovery stick. Cant seem to get it created correctly. Ill keep trying. If anyone has any hints, please throw them my way!
Thanks
--tom
Boot up.
SYSLINUX 3.31 v1.06 Fri Jul 9 18:03:04 PDT 2010
Copyright (C) 1994-2005 H. Peter Anvin
Debug Serial Port Enabled
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading
18
1B
To Be Filled By O.E.M.
11/17/2008 ReadyNAS-NVX V1.3
kernel..................................................
Loading initrd.gz.....................................................................Ready.
[Hardware Error]: No human readable MCE decoding support on this CPU type.
[Hardware Error]: Run the message through 'mcelog --ascii' to decode.
▒ahci 0000:03:00.0: masking port_map 0x7 -> 0x3
request_module: runaway loop modprobe binfmt-464c
sd 5:0:0:0: [sdb] Assuming drive cache: write through
OS Reinstall
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall OSReinstall
Loading
18
1B
Tech Support
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall TechSupport TechSupport
Loading
18
1B
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest update...
Really having a hard time creating the USB recovery sticks. Finally ordered some 2GB ones and its the closest I have been. Now when I boot from the USB I get.
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key
I usually had nothing! Getting closer... Anyone have any hints / help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The USB key must have a partition on it. Not all USB keys are compatible.
Which version of Windows are you using to create the key? Are you running the usbrecovery.exe as an Administrator?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using Windows 10... After trying just letting windows format it, i figured i will try using diskpart.
Commands I used in diskpart...
clean
convert mbr
create part pri
format fs=fat32 quick
Then I used the USB recovery software on it, (right click and ran as administrator) After completes, use windows and eject.
Single drive in Slot 1 of NAS box. Power off... Wait 10... Power on holding backup button with USB stick in front slot.
Console clears screen, and then I get:
Still think its user error with making the usb recovery. anyone have a something else i can just dd or something for it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Turning on quotas.
nas-AA-15-30 login:
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ReadyNASes, especially older ones, are very particular about the USB stick you use. I didn't try 6. But after 2 that failed, I remembered I had a really old 2GB that was considered big in its day. It worked like a champ. Glad you finally found the right combo.
