- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 6 OS Upgrade from 4.2.30 to OS 6 then adding PLEX addon, which .deb file to download ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
im about to do the upgrade on my RNDP6000 (12TB) 4.2x to OS 6 (just waiting on my 12TB backup being done first....taking days)
I see that Plex addon can be installed but when i goto Plex download page i have two possible options...
1. Netgear
2. Linux
if i choose to download for Netgear Nas, i only get a x64 version (but nas is x86 right ?)
if i choose Linux i do see a X86 version.... is this the one i should choose (Linux - Ubuntu or Fedora , which ??) and not (Netgear) as one would expect to choose ?
https://i.postimg.cc/bJ0GwK5f/plex-netgear.jpg
https://i.postimg.cc/90WDRL3R/plex-linux.jpg
thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@xlr8r wrote:
since the drives are empty anyway why do i need to wait 26 hours on a sync ?
A RAID array is a virtual disk that provides raw block storage. Every block on the physical disks needs to be either read or written when the array is created - that is needed to construct the parity blocks that provide RAID redundancy. The fact that the file system "on top" of the virtual disk is empty doesn't matter - the process is the same whether the file system is full or empty.
There's no way around this step. You can start to put data onto the NAS while it is resyncing, but I suggest waiting until it's done. The NAS performance is slower during the resync, and copying files onto the NAS now will also make the resync take longer.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 6 OS Upgrade from 4.2.30 to OS 6 then adding PLEX addon, which .deb file to download ?
Choose Netgear(not Linux) at https://www.plex.tv/media-server-downloads/ and then select the 64-bit Intel package. The download will end with .amd64.deb.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome to the Community!
You can select NETGEAR X86 refers to the family of processors (Intel,AMD) while x64 is the current computer architecture which is 64-Bit. Most Intel and AMD processors now supports 32 and 64 bit
The NETGEAR Package for 64 Bit is .deb which is an extension for Linux Debian which ReadyNAS uses.
HTH
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
many thnaks guys for the fast response.
fingers crossed for the 4.2 to OS 6 upgrade
and then onwards , to PLex....
...silly question, is there already a Plex version built into the OS6 firmware upgrade in APPS ? (that has a toggle switch) ?
just thought i read that somewhere in one of the many posts ive been reading....
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
one other question I would like to ask if i may about the 4.2 to OS 6 upgrade...
i see a couple of variations in the tutorials for the process.
One method says to import PREP4TOR6_0.1-x86.bin via the addons page and then R4toR6_6.9.5.bin via the firmware update page...?
and the other says,
To add both files (PREP4TOR6_0.1-x86.bin & R4toR6_6.9.5.bin) via the firmware update page ?
which method is the corrrect one ...?
many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
and the other says,
Use the first method.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Plex originally distributed the server through Netgear, but later on they decided to distribute it directly.
You install the app you downloaded using the upload control on the apps page of the web admin ui. After you install it, it will show up in the admin web ui (complete with toggle switch).
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks
what would happen if i did firmware update via method 2 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok so its 100% this method
DO NOT REBOOT
and then import R4toR6_6.9.5.bin via the firmware update page...?
correct ?
is says different here (ie. to use method 2 - both files imported via firmware update page ?)
and here
https://it.megocollector.com/tips-and-tricks/readynas-pro-upgrade-firmware-from-4-to-6-unsupported/
- Mark as New
- Bookmark
- Subscribe
- Permalink
DO NOT REBOOT
correct ?
and here
I suspect both methods would work, but the more recent posts on this say to install the prep bin as an add on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
to be sure am I using the correct PREP4TOR6_0.1-x86.bin file ... ?
i see a couple of variations of this floating about. one named
and the other
PREP4TOR6_0.1-x86-addon.bin
should i assume these are both the same thing just named differently ?
I just want to be sure I have the correct file to install as an addon and not maybe an earlier version that is uploaded only via the firmware update method ?
i.e. i have downloaded the files posted in this thread...
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those are the correct links.
If you also want to update your bios, do that before you do the conversion. You'd install this binary as an add-on: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank everyone for the great help.
i have downloaded all the files i believe I need to get going ...
PREP4TOR6_0.1-x86
does it matter if i just use the latest firmware from Netgear to upgrade , ReadyNASOS-6.10.2-x86_64.bin
or must i use the R4toR6_latest.bin file (no idea what version it is though) ... ?
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Use the links I posted in https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-R4toR6-download-links/m-p/... .
Then update the NAS firmware after the conversion (and after your RAID array is rebuilt). It should give you a pop-up offering to update the firmware. If it doesn't, then use the check for updates link on the system->overview page of the OS 6 web ui.
Trying to directly install the current OS 6 firmware won't work. _latest.bin isn't available for download anymore.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks StephenB
i have just completed the first stage of the OS upgrade.
i see the volumes are "re-syncing" which will take 26 hours???
is it necesssary to wait on this or is there a way to cancel and start a new format or something ?
just trying to save some time ....
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
perfect thanks
ive waited for a week for my backups to get created so i can wait another day on this to happen i guess.
new OS looks great
looking forward to getting stuck into the settings once syncing completes.
many thanks for all the help..
great to see my old Nas get a new lease of life...
- Mark as New
- Bookmark
- Subscribe
- Permalink
One additional advantage you'll be glad of if needed: If your NAS does stop functioning, or you just want to upgrade to a faster one, you can move the drives directly to a current OS6 NAS. No need for the temporary mount method needed to move 4.2.x drives to an OS6 machine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
first glitch so far...
cant get readynas email alerts to work. Im using exact same settings as old 4.2 firmware ?
do i need to change something on OS6 to get same settings to work?
[name]@btinternet.com
mail.btinternet.com
[password]
port 587
TSL ticked
- Mark as New
- Bookmark
- Subscribe
- Permalink
May I ask what exact version of the OS6 you are running now on your readynas ultra 6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@xlr8r wrote:
port 587
The settings should be the same.
But the information I am seeing says that you should be using port 465. http://bt.custhelp.com/app/answers/detail/a_id/44917/~/what-are-the-settings-for-outgoing-and-incomi...
- Mark as New
- Bookmark
- Subscribe
- Permalink
latest 6.10.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
ive tried every possible combination in email settings and always get an error?
https://i.postimg.cc/FRbB3Qtv/nas-email-error.jpg
i cant understand why these setting worked before the upgrade and now dont, clearly the new OS is the issue ,,,,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I posted the settings that you should use (from the BT website):
Outgoing Mail Server: mail.btinternet.com
Port: 465
SSL Encryption: Enabled (but not STARTTLS)
Authentication: PLAIN
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet or btopenworld password
