Orbi WiFi 7 RBE973
Reply
Unable to connect to ReadyNAS Admin page
guillaumeparis2
Hi,
I can't access to my readyNas admin page. When the ready nas boot it get an ip that I can ping but after the boot process I'm unable to access the admin page or ping the nas. I try the factory reset procedure but I get the same result. Does anyone have a solution to access the nas ?
Thank you
Model: RN102|ReadyNAS 100 Series
Message 1 of 5
Guru
Re: Unable to connect to ReadyNAS Admin page
What ReadyNAS model do you have?  Have you looked at RAIDar's status?
The normal logon is https://nas-ip-address/admin  using the real IP address for the NAS.  There will be a logon popup, the username needs to be admin and the password is the default password for your ReadyNAS model.  Most use either password or netgear1 as the default.
Message 2 of 5
guillaumeparis2
Hi,
Thank you for your answer. It's a ReadyNas 102.
During the boot, raidar detect the NAS and give me the ip address, ip addres that I can ping during the boot process. When the boot finish and the power led stop blinking, Raidar doesn't detect the NAS and I'm unable to ping the NAS.
I try to do a factory reset but I have the same result.
Thank you
Message 3 of 5
Guru
Power down and remove the disks (labeling by slot).  Then power up.  Let us know if RAIDar gives you a "no disks" status (and if you can ping the NAS).
Message 4 of 5
guillaumeparis2
Thank you verry much.
After starting the NAS without  any disk, I was able to do a real factory reset. Now I have acccess to my NAS.
The only bad point is I have lost all my data.
Next time I will prevent the lost by backing up may datas regularly.
Thank you
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2950 views
  • 0 kudos
  • 2 in conversation
Announcements
