Orbi WiFi 7 RBE973
Reply
Upgrade from 516 to 628
vrspectre
Apprentice
So I just upgraded my 6TB drives to 10TB drives. Loving the extra storage. Now I've decided it's time to upgrade the chasis too.
I'm probably going to go with the 628. I've seen posts about people just dropping the disks into a new NAS in the same order after they have the OS setup and on the same version when doing a replacment of the same model.
Will that work when changing models like this?
Model: RN51600|ReadyNAS 516 6-Bay Diskless
Message 1 of 2
Accepted Solutions
Guru
Re: Upgrade from 516 to 628
Yes, that will work.
If the firmware in the 628 doesn't match what's on the disks, then the newest version wins.  That is, if the disks are running a newer version, then the flash is updated from the disks.  If the flash is newer, then the disks are updated to that firmware version.
You might want to match the two versions before you migrate, just in case.  The easiest way to do that is to start by installing a spare disk into the new NAS, and install matching firmware before you migrate the disks.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1652 views
  • 4 kudos
  • 2 in conversation
Announcements
