× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Wake-on-LAN always powers up NAS
DoctorBrown
Apprentice
The Wake-on-LAN feature appears to be completely broken on my ReadyNAS 102. If the WOL feature is enabled in the Power settings, the system will not stay powered off if the network cable is plugged in. I know this sounds impossible, but I tested this extensively.
If I power off the NAS from the front panel, it goes through the power off. About 5 seconds later the system powers back on. If I disconnect the LAN cable from my switch, the NAS stays off. As soon as I plug in the cable, the system powers on. This will occur with NO OTHER DEVICES plugged into the 8 port switch.
I believe that this started when I upgraded to the lastest firmware version. I was going to backdate the firmware but the NAS doesn't allow me to do that.
Two Questions:
1. How can I backdate the Firmware to confirm that it is the new firmware. Hopefully without wiping out my Disks.
2. Is there a way to fix this with the latest firmware.
My environment:
Netgear Router WNDR3700
Netgear 8 Port Switch - GS108
Netgear ReadyNAS - RN102 Firmware: 6.4.1
Asus P7P55D-E Motherboard
Windows 7 x64 Pro
Message 1 of 3
Accepted Solutions
Guru
Re: Wake-on-LAN always powers up NAS
There is a fix for this in 6.4.2 RC1 https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-RC1/m-p/999457#U999457
So one option is to install that.
You can manually downgrade to 6.4.0 (but not before).  However if that is the only issue you are having, then I'd suggest going with 6.4.2 beta instead.
Message 2 of 3
All Replies
Guru
Message 2 of 3
DoctorBrown
Apprentice
StephenB, Thank you for the very quick reply! I upgraded to the 6.4.2 RC1 and it solved the problem.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3498 views
  • 0 kudos
  • 2 in conversation
Announcements
