× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
apt-get upgrade breaks duo?
izardx123
Follower
Hello,
Whenever i do apt-get upgrade, i have todo a factory reset, everytime
Any ideas why?
Craig
Message 1 of 3
TeknoJnky
Hero
Re: apt-get upgrade breaks duo?
apt-get upgrade is not supported, so don't do that.
readynas uses a customized kernel and many custom packages which can get overwritten if you do a global 'upgrade'.
you should only upgrade specific packages that you may have installed manually or that are not part of the core os.
Message 2 of 3
mdgm-ntgr
NETGEAR Employee Retired
Frontview requires the old libc which the apt-get upgrade replaces. It's possible an OS Re-install may be enough to fix the problem but it may not be in which case you can do a factory reset or see if support can help (fee would be involved and does depend on what commands you entered).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 857 views
  • 0 kudos
  • 3 in conversation
Announcements
