- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
firmware update doenst work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
actual firmware 6.1.6
every restart message will prompt: upgrade to 6.2.5 -> ok
download works, restart, nothing to see.
no information about problems in systemlog
test with manually download fw 6.2.5 an update -> restart -> same problem
test wtih fw 6.6.0 -> same problem, no infromation eg.
didn't find infromation about this problem...
the first problem is -> usb hard drive will listet with modelname in logfile (not identified) but is'nt see in system overview to reformat the drive (2TB mybook)
reguards Tobias
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: firmware update doenst work
Is your issue that the firmware updates failed? (That is the web ui still says you are running 6.1.6).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, message FW Version 6.1.6.
Found another Thread (workaround):
Info under:
http://kb.netgear.com/29974/ReadyNAS-OS-6-RN100-RN2120-cannot-update-due-to-invalid-checksum?cid=wmt...
(Checksumproblem)
But this works only from FW 6.1.9. Informatiosn about older Versions and resoultion -> link is broken.
Tobias
- Mark as New
- Bookmark
- Subscribe
- Permalink
That article only applied to 6.4.0 upgrades.
Do you have any apps installed? Also is ssh enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems 6.2.5 was on the internal flash but the OS on the disks was still on 6.1.6.
Your system should update to 6.5.2 when you next reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hallo,
Thanks a lot. -> after reboot 6.5.2 was activated. After this i take upgrade to 6.6.0 -> it works.
But my first problem was "usb Device 2TB WD Mybook" could not be found.
One Time Systemlog wrote:
Mi Dez 14 2016 8:56:25
System: Externes Speichergerät ist verbunden, aber das Dateisystem wird nicht erkannt.
Filesystem was NTFS, Partition deleted on PC (usb connection) -> at netgear nothing works. Use antother data cable, nothing works. test USB hard drive on PC -> works fine.
after download actual log files:
file: usb_storage.txt
*** Connected devices ***
/dev/disk/external/3:1:WDC_WD20EZRX-00D8PB0:WD-WCC4N7HCDHKE:480:-22 -> ../../sdb
file: usb_device.txt
1-0:1.0
1-1 product=My Book 1230 idProduct=1230 idVendor=1058 devnum=3 speed=480
1-1:1.0
2-0:1.0
3-0:1.0
but no entry under System/Overview ;-(
any idea?
-> want use this drive for offsite backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure on the cause of the USB issue, but there are some fixes related to USB detection in 6.6.1 beta.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
sorry, doesnt work,
no entry in system/overview. Only one share shown on internal NAS storage
there is no option to use this blank disc.
is there problem with 2 TB USB drives or is there compatibility list available?
any idea?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you check the shares page?
Also, the log should include a "System: External storage device connected." message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, viewed
but no entry under shares , Volumes, e.g.
actual no way to see USB storage.
Message one time in Log only:
german: System: Externes Speichergerät ist verbunden, aber das Dateisystem wird nicht erkannt.
english: external storage indetified but file system could not be recognised.
