Orbi WiFi 7 RBE973
Reply
problem creating a new rsync backup job
Hello friends, not sure what I'm doing wrong here. I'm trying to create another rsync backup job to the front usb port.
I'm matching the process I used on the other jobs I've created but I'm getting an error when I Test Connection:
Unable to connect to remote folder. Invalid network name or permission denied. Code: 7077010012
-Here are settings from a job that has no problem:
From remote system
Host: 127.0.0.7
Protocol: remote:Rsync Server
Port: 873
Path: jobs
If I test connection on this job it's fine.
-But if I set up a new job from a different share:
From remote system
Host: 127.0.0.7
Port: 873
Path:audio-video
If I test connection on this job it gives me the error.
Any and all advice is greatly appreciated!
thanks
Ken
Model: RN426| ReadyNAS High-performance Business Data Storage - 6-Bays
Message 1 of 6
Accepted Solutions
Guru
Re: problem creating a new rsync backup job
@Hopchen wrote:
Very likely the issue is that rsync is not enabled as a protocol, on the USB.
I  assumed that both backup jobs were going to the same USB drive - if that's the case the issue is more likely to be on the source share.
But rsync needs to be enabled on both the source share and the destination.  So check both.
Message 4 of 6
All Replies
Guru
@KenTanker0us1 wrote:
Host: 127.0.0.7
This should be 127.0.0.1
From remote system
Host: 127.0.0.7
Port: 873
Path:audio-video
Also, make sure that rsync is enabled for the audio-video share.
Message 2 of 6
Hopchen
Prodigy
The "Test Connection" just tests that the destination is reachable via the protocol (TCP port) you want to use (in this case, rsync). Very likely the issue is that rsync is not enabled as a protocol, on the USB.
It should not matter whether you use 127.0.0.7 or 127.0.0.1 as all 127.x.x.x address point to the loop-back. However, it is normal practise to use 127.0.0.1
Cheers
Message 3 of 6
Guru
Message 4 of 6
Hopchen
Prodigy
Ahh yea that could be it @StephenB
You are right, it might be the same USB 🙂
Message 5 of 6
Solved!! Thank you very much my friends.
I didn't have the rsync enabled.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2452 views
  • 0 kudos
  • 3 in conversation
Announcements
